I cannot believe that worked !
Old Feb 1, 2010 | 03:55 PM
Steven20063's Avatar
I just traded my buddy my truck for his 3rd gen. Camaro, but discovered it had both head gaskets blown (found thanks to UV dye and a blacklight) , and called my buddy to find a quick fix other than actually replacing them which I am doing this weekend , and he recommended Alluma-Seal (sp?) by Bar's Leak.
It's made from freakin ginger root !!
I put in in and let it run for about 15 minutes and BOOM! Problem fixed !
Old Feb 1, 2010 | 11:55 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: I cannot believe that worked !
It might be fixed for now, but for how long. I would fix it soon as you can, it's not a hard fix. Then flush your rad.
Old Feb 2, 2010 | 12:01 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I wonder what it is actually doing? It must be swelling the gaskets or something.
And it probably won't hold up when the motor is under a lot of load.
Old Feb 2, 2010 | 12:11 AM
84Z28406's Avatar
That stuff basically clogs any tiny hole it comes across. I remember there being a bunch of those somewhere in these cars... Oh yeah, rad and heater core.
Old Feb 2, 2010 | 10:25 AM
yea i was wondering if that junk would clog anything else...
Old Feb 2, 2010 | 03:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yep it will. That crap is nasty just wait untill you pull the cap off and have brown gunk comming out the of the radiator. Its more of a im on the side of the road and need to get home fix. Ive used the head gasket in a bottle before many different brands just to get the car good enough so it can be driven away to be traded in. Some times it held across town to the dealer ship sometimes it dident.
Old Feb 2, 2010 | 03:57 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
might cause bad long term affects but seems like it may work for now...id look into getting them replaced.
Old Feb 2, 2010 | 04:30 PM
I am getting rid of the motor anyway...I have a 350 lined up for it that I will be picking up this weekend.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
