91 Firebird, 305 TBI, wont start.....
Old Feb 15, 2010 | 10:58 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
As listed, the engine will not crank. I can run it on starter fluid when I crank it from a trigger attached to the starter. I try to start it from the key ignition, I get the console lights at the run postion, but it will not crank at the start position. The temp gauge pegs out but nothing happens.
So far I have:
Replaced the ignition module. No change.
Replaced the steering column start linkage and column dimmer switch while I was there. No change.
Replaced the Neutral Safety switch on the shifter. No change.
The injectors will drop gas at the initial trigger crank and at the end of the engine shut down, but that is it. The car has a clifford alarm, but I haven't had it hooked up on the battery for over 4 years.
Any ideas?
Jim Berry
Old Feb 15, 2010 | 11:25 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: 91 Firebird, 305 TBI, wont start.....
sounds like the VATS system
http://sethirdgen.org/vats.htm
none of the stuff you replaced has anything to do with it only droping gas for the 1st and last second of the crank ...... but atleast you got some new parts
Old Feb 16, 2010 | 11:24 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
I even used another key that I have for the car and get the same result. Turn the key to "start" and get nothing. I don't even see the VATS light illuminate. Is it possible that VATS is not on this car? Why would the PO have a clifford alarm installed with VATS present? With that said, I will check for the wires and resistance in a few days.
Jim Berry
Old Feb 17, 2010 | 06:05 PM
89RS_82Z's Avatar
it could be the vats itself not the key, and the security bulb is blown or lose
seem like vats to me
i have vats and a viper alarm, i know my alarm will kill the starter
Old Feb 18, 2010 | 12:07 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
I will give a look this Sunday. Too much work and getting home to late to check. I even tried another ECM and still same results.
Jim Berry
Old Feb 22, 2010 | 12:04 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Checked the resistance of both keys today. They show .870 to .871. Spent too much time on the GTA today to look for the VATS wires, but I will look tomorrow.
Thanks for the help so far.
Jim Berry.
Old Feb 22, 2010 | 11:13 AM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
since you said the car had an alarm it pobably is vats acting up, have you tryed removing the alarm completely, it porobably has a box or somrthing wired into the ecm or vats module to bypass the factory vats so it will work with an alarm, its a thought, or could just be tied into it and something came loose or didnt agree with it. I had been looking into just about everything on vats for the last couple months due to issues with my car not starting. when you turn your ignition on at first when all the lights light up do you see the secutity light at all? i think its supposed to light up with the others showing its working, if not it could be bad bulb. I could be wrong because mine showes up while turning the ignition for about a second and again if it try to crank the car, so I'm not sure on when its supposed to light up, as that I havent figured for sure whats going on with mine. all I know is everyone says mines not a vats issue.
Old Feb 22, 2010 | 11:47 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
The alarm is a clifford set. It has two pigtails into a main flask size box. If I remove theses two pigtails, I do not think they will plug into each other. Lots of wires go different directions on this. Not something I want to tackle. I would probably tow it to an alarm shop to remove it.
Jim Berry
Old Mar 16, 2010 | 11:03 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Used the VATS guide that is on this site. I checked the VATS light on the instrument panel. Light is good as I switched it with the "brake" light and it lights up.
When I attempt to start the car, everything lights up once with the exception of the VATS light. I don't get any flashing VATS light at all. I do still get the code 53 on the computer. Everything is normal with the exception of the temp gauge needle pegging out at 260 when attempting to start.
So far I have replaced the following: Starter, steering column starter switch, light switch, ignition module, neutral switch, battery, ECM, and finally today the oil pressure switch. Whats left? Cigarette lighter and right rear tire?
The VATS guide says to look for white wires wrapped in either a black or orange sleeve which travels up the steering column to the ignition switch. Can't find any of that. Most wires travel up a translucent sleeve up the steering column. I have a VATS fuse and a spot on the instrument panel that doesn't illuminate.
Again, the car has a Clifford alarm that has been disconnected for 4 years but still wired in. I connect it to the battery and all appears to work as it should. I can start the engine by a remote starter switch, but cannot get fuel to run continually. Starter fluid will keep it going as long as I am spraying it. Not condusive to driving down the highway. I get one squirt from the injectors at start up and one just before it dies.
So far I am completely befuddled. I am just short of rolling it out of the garage and setting it on fire. A funeral pyre. A fitting end for a "Firebird".
Jim Berry
Old Mar 18, 2010 | 08:14 PM
89RS_82Z's Avatar
ok my security light comes on for a few seconds then goes off
if i put tape over my chip the light dont come on and i get no starter
i will check my dealer service manual tonight or this weekend whenever i go back home...... see what it says about one pulse of the injectors
wait, you know i think it may be the fuses
labeled INJ1 and INJ2...... i think this is what mine did when i pulled the fuses, but cant remember
Old Mar 19, 2010 | 12:36 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Located those fuses. Still good. Still no start.
Old Mar 27, 2010 | 04:11 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Soooo....I'm chillin' at home on a weeks leave. Got the GTA running, Trans Am is running, and still working the '91 issue. So I get bored and start looking for wires again. I find two white wires wrapped in an orange cover, but tagged with an warning label that attaches it to the airbag lines. I break out the volt meter and I get no continuaty (sp) on the line. Could it be the mysterious broken wire on the lock cylinder that I am looking for? See for yourself.
Attached Thumbnails 91 Firebird, 305 TBI, wont start.....-airbag-wiring.jpg   91 Firebird, 305 TBI, wont start.....-lock-assembly.jpg   91 Firebird, 305 TBI, wont start.....-lock-cylinder.jpg
Old Mar 27, 2010 | 08:56 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
I went to O'reillys and purchased a new lock cylinder. Came with a key blank but no keys with a chip. You have to take the blank to the dealership. Sooo...I fixed the wires on the current lock cyl and fed everything back down the steering column with two newer and more protected wires. Checked the resistance at the bottom of the column and I still get .871 on the key, so all is well on that end. However, no start but now the security light flashes on for about 2 seconds. I will tackle a little more tomorrow.
Jim Berry
Old Mar 28, 2010 | 07:43 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Put everything back together and still have the same resistance at the column. Now when I turn the key, I hear a clicking sound in the left front kick panel. It appears to be a start relay. I will stop by the dealership tomorrow and see if I can track it down.
Jim Berry.
Old Apr 6, 2010 | 11:23 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Hey, I'm back. A little Bronchitis couldn't keep me down. Anyway, located the relay in the kick panel. VATS relay according to the dealership parts guy. (Who by the way has been able to find anything that I need for the 3rd gens.) I replace the relay and "viola" she starts. What are the odds that the problem was the ignition key and the relay? at the same time?
Jim Berry.
Old Apr 10, 2010 | 01:33 AM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
I am having the same exact problem, except that I replaced the lock cylinder 2 months ago. So all it was is the small relay mounted next to the module?
Old Apr 10, 2010 | 05:46 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Well, could be. But also make sure that your car is in park or in neutral and try again. The VATS relay in the kick panel is also available at Oreilly for about 16 dollars.
Jim Berry
Old Nov 20, 2010 | 11:44 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
So after moving it out into the driveway behind my brothers F150 in my driveway. It will not start for about a month. Again.
I had taken the center consol out and had completely torn down the rest trying to figure out if it is the NSS. I pull it off, look at it and move it into various positions while trying to start the engine. The "securiity" light comes on again.
I put the console back to gether again and bingo it starts. Now the fuel pump won't shut down unless I pull the hot lead on the battery. WTF?
Jim.
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
MENINBLK
Aug 5, 2015 11:58 PM
