Distributor not sitting all the way?
Old Mar 13, 2010 | 11:22 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
It seems like my new Streetfire Dizzy isn't sitting all the way... Can anyone chime in as to why it would do this?
Old Mar 13, 2010 | 11:24 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Distributor not sitting all the way?
umm... if I remember correctly, there is a shaft connected to the oil pump or something inside where the distributor goes in, look in there with a flash light, you have to align it with a screwdriver to where it will align with the dizzy...
Old Mar 13, 2010 | 11:33 PM
JTNKTZ's Avatar
Engine: 355/350
What if I turn the motor would it seat then?
Old Mar 13, 2010 | 11:35 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
If you do that you will mess up the timing and you will have to set the base timing.... I don't have concrete information, there is a post about the steps to set the base timing though....
Old Mar 13, 2010 | 11:37 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
https://www.thirdgen.org/forums/engi...e-down-me.html
Old Mar 13, 2010 | 11:54 PM
Awesome-X's Avatar
Car: 87 Camaro
You can stick a flathead screwdriver in there and turn it if need be. I used to an old distributor shaft and machined a piece so that it would be spot on and I wouldn't have to hunt for the shaft.
Old Mar 14, 2010 | 12:37 AM
JTNKTZ's Avatar
Engine: 355/350
I got it to sit. Just bumped the starter a few times.
Old Mar 14, 2010 | 01:05 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I've used that very method many times.
I just install the distributor with the rotor tip pointed where I wanted it and, with the harmonic balancer mark set at the BTDC timing mark I wanted on the compression stroke. I then just bumped the engine. At some point the distributor would drop all the way down. BINGO!
Jake
MM2Robinson
Oct 1, 2017 09:16 AM
amargari
Nov 10, 2015 02:09 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
