[[Quick Question: Hole in back of Block?]]
Old Mar 16, 2010 | 05:30 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Old Mar 16, 2010 | 06:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: [[Quick Question: Hole in back of Block?]]
Oil pressure sending unit or switch, or a pipe plug if you don't use one there.
Old Mar 16, 2010 | 06:16 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
So...what do i need? im thinkin ill want a oil pressure gauge...
Old Mar 16, 2010 | 06:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'll need whatever's required for whatever gauge you use.
Old Mar 16, 2010 | 06:36 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Oo...gotcha, so that can be added any time basically? Like I could plug it now and later (once I get gauges) put in whatever it is ill need for my gauge?
Old Mar 16, 2010 | 06:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes as long as you've always got something plugging that hole you can put whatever you want in there any time.
Old Mar 16, 2010 | 08:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Be sure to use a non-hardening sealer on the plug/fitting threads. NO teflon tape.
Also note that it is funny as all get out' when some one forgets to plug the hole. When the prime tool starts to move oil it looks like an oil well was just un-capped. And of course the person doing the priming ends up wearing a bunch of that oil. Seen that done, laughed so hard I thought I cracked a rib.
RBob.
Old Mar 16, 2010 | 11:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Better yet when someone does it without priming. If the oil pump moves an impressive amount of oil when a drill is driving it, imagine when it's running at speed.
Old Mar 17, 2010 | 04:50 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Thanks alot guys, I greatly appreciate the help!
Old Mar 18, 2010 | 01:01 PM
shanep1991's Avatar
its not funny when you forget to plug that whole when your the one drenched in oil, i did that on my very first engine build at 16, i felt like and idiot lmao
Old Mar 18, 2010 | 01:55 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Ill be sure to plug it, thanks alot guys!
Old Mar 18, 2010 | 02:38 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Make sure no trash fell/falls down into that oil passage.
I prefer to use brass or stainless plugs to avoid chance of seizing.
People have their favorites, but I prefer the orange/red high-temp RTV as sealer.
By the way your engine pic is blinding.
Old Mar 18, 2010 | 04:41 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Thats what Im goin for...shes quite shiny. Its goin in a show car so its gunna be off the walls by the time im done.
Infested
May 22, 2018 11:56 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
lakeffect2
Aug 23, 2015 08:44 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
