Oil Filter stuck
Old Mar 24, 2010 | 10:02 PM
S91Formula5.7's Avatar
Car: 1991 Pontiac Firebird Formula
Transmission: 700 R4
Oil Filter stuck
well, I'm in the process of changing my oil/filter, and its the first time i have on this car. i just spent the last 5 hours trying to get the filter off. i started by using a filter wrench, to no avail. next, i tried putting a screwdriver through it, and turn it, but the walls just bent, and it wouldn't budge. now im here, after attempting to grind through it and everything.
Any and all help is greatly appreciated.
thanks guys.
Attached Thumbnails Oil Filter stuck-dscn0497.jpg   Oil Filter stuck-dscn0498.jpg
Old Mar 24, 2010 | 10:06 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Oil Filter stuck
That looks like fun.......
Grab a hammer, and a chisel. Preferably a relatively sharp one, so it can get some bite. You don't want to cut...... Hold the chisel perpendicular on the raised ridge there on what is left of your oil filter, and give it a couple whacks to it has something to bite, then tilt the chisel, and whack it with the hammer, in the direction the should unscrew whats left there. Once it breaks loose, it should come off fairly easy.
Old Mar 24, 2010 | 10:27 PM
Stephen's Avatar
Car: 87 GTA
Is it the original filter, from the assembly line in 1991? I have never heard of an oil filter stock that bad.
Maybe you'll hafta create your own "wrench", by taking a flat/square bar & welding a couple of little studs that fit into the holes inside the filter & wrenching it from there. That way all your wrenching force would be concentrated on the center where the threads are.
Good luck!
Old Mar 24, 2010 | 10:41 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello S91Formula5.7!!!
Looks like someone didn't put oil on the gasket surface before putting on the filter!!
Also must have really tightened it up with the oil filter wrench!!
You could try tack welding/jamming (welding preferred) two small deep sockets into the small holes, and then wedging a long breaker bar between them, to turn it, it'll give you the leverage that you'll need!!
Old Mar 24, 2010 | 11:19 PM
I tried that, many times with no success. i also tried heating it up first, then trying too loosen it with a hammer and chisel.
Its not the original filter thank god, but it really doesnt want to come off.
I dont have a welder, but i did try your method with needlenose pliers, but they snapped. im still searching for a creative solution for a multi headed 'wrench'
ill have to try the breaker bar/ deep socket method tomorrow, and ill get back to you guys. in the meantime, im open for more ideas... and thanks for your help so far.
Old Mar 24, 2010 | 11:25 PM
Good luck!!
Keep us posted!!
P.S. Don't forget to lube the sealing gasket with oil, any only hand tighten 3/4 to 1 full turn after gasket contact!!
This makes it easier to get the filter off the next time!!!
Old Mar 25, 2010 | 01:07 AM
bayman's Avatar
need help new to site and can not figure out how to post
Old Mar 25, 2010 | 06:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Top or Bottom left, "Post Reply" button.
JamesC
Old Mar 25, 2010 | 07:11 AM
Twin_Turbo's Avatar
Do you have friends @ a machine shop?
Because of the same issues with filters and not having enough room to get a hammer and chisel/drift in there and whack it I made these. I have them in several sizes for diff style filters (hole locations). Something like this will get the filter off:
It obviously goes in from the other way when the case is torn off but you get the idea.
Old Mar 25, 2010 | 12:46 PM
that would be really helpful, but i dont know anyone at a machine shop... sadly, i think im going to let this one be handled by a professional with a lift. i hate to give up, but im undertooled and i dont have enough space with my ramps to really do any damage. so thanks guys for your ideas, much appreciated
Old Mar 25, 2010 | 12:50 PM
Stephen's Avatar
Car: 87 GTA
Those look like what I was describing above. No need for a machine shop, or even a welder really. Just a drill, drill bits, bolts, nuts & a bar to use as the handle.
Old Mar 26, 2010 | 01:52 PM
Don't give up, take a look at the pictures of Twin_Turbo's machine shop gizmos, "a picture is worth a 1000 words", and make something!! Use your imagination, it'll save you some money, and you'll get that great satisfaction of doing it yourself, cheaply!!
Some flat stock (metal pieces) , and some nuts, and bolts will work!!!
Have you got a wide blade putty knife????? Drill some holes in the blade, that match the holes in the filter base, and screw the bolts into the filter base, use the handle to twist the filter piece off!!!
IMAGINATION!!!!!
Old Mar 26, 2010 | 03:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You might want to try taking a hammer & chisel and split the filter base close to the threads. Do that in 2 or three places, it should release. If you happen to ruin the mount threads, you can get a new mount (by-pass) to replace this one.
Old Mar 26, 2010 | 07:32 PM
Hello five7kid!!
That would be too easy!!!
Old Mar 26, 2010 | 07:40 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Do you have access to an air chisel? Comes in handy where space is limited.
Old Mar 26, 2010 | 07:52 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Lol be careful though! It's all fun and games 'till you air chisel a hole in your oil pan :P
Old Mar 26, 2010 | 08:51 PM
Damon's Avatar
The problem is always that the rubber gasket is glued onto the metal mounting surface. Key is to break the seal. I have a screwdriver that I heated and bent at 90* very close to the tip. Wedge it in there and pry that b1tch up to rip the gasket away from the metal in several places. Then have at it with a chisel and hammer to get it started with being unscrewed.
This kinda work isn't for the faint of heart. It's ugly and medieval. I know when they're stuck, they're REALLY stuck.
Advice: Getting ticked off helps. Puts you in the proper metal state for a job like this. Not so enraged you stop thinking, just angry enough you're not going to let a little piece of stamped sheet metal and a rubber gasket beat you. Some Metallica playing in the backround is absolutely appropriate for this kinda work.
So I ask.... You're not going to let an oil filter make you tuck your tail between your legs and run to your local mechanic, are you?? Well, are you?? Man up. Get that b1tch off of there yourself or your car will never respect you again. Go do it. Do it NOW.
Old Mar 26, 2010 | 10:29 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
What I would do is get a few big bolts and hammer them up through the holes then use a crow bar for leverage... I would make a diagram but I am too tired. Also try wd-40 it a little?
Best motivational post EVER.
Old Mar 26, 2010 | 10:35 PM
JTNKTZ's Avatar
Engine: 355/350
Just a quickie but you get the idea
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
