305 L69 or LG4?
Old Apr 6, 2010 | 12:41 AM
3rdGenSuperman's Avatar
Car: 1983 Camaro Z28
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
305 L69 or LG4?
Ok, try not to flame me to bad.
I have a 83 camaro 5.0. I'm trying to figure out if it's the HO or not.
Simple answer check the vin....well the windshield vin plate is rusted and you can't see it, door sticker is not visible, meaning you can't see vin. When I brought it from US to Can because of this Vin problem I had to register with the DMV here and they issued a new vin number, which matches in no way to the correct format. They had to take the previous title and issue a new one with the new vin
all this being said I can't look at the 8th digit for the engine code.
Where exactly can the engine code be located. Is there anything defining on the motor or about the carb that I would be able to tell. The engine compartment is completely stock, EGR system in place and everything.
There is a stamp on the Top of the Rad support, but I didn't see either of the corresponding codes there and I'm not sure how to interpret it.
any thoughts?
Old Apr 6, 2010 | 01:59 AM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Re: 305 L69 or LG4?
any thoughts?
I may be wrong, but isnt there an rpo code in the glove box in the hatch? also it could be stamped onto the block, im not sure though.
Old Apr 6, 2010 | 02:12 AM
the_am_man's Avatar
Car: 82' T/A
Engine: LG4
Transmission: THM200c
Re: 305 L69 or LG4?
I believe the HO cars had better exhaust manifolds than the regular LG4 models, which means there should be a visible difference between the two. I could be wrong though, and the only way to check is to find pics of the two.
Old Apr 6, 2010 | 02:20 AM
87_LG4's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Transmission: TH-700R4
Re: 305 L69 or LG4?
Also, if the engine is completely stock, then the L69 would have a dual snorkel air intake, which imo would be the easiest way to tell them apart. And as Ilike2stroke383 said, there should be an RPO sticker on the underside of the glove box lid. The engine code will be stated there.
Old Apr 6, 2010 | 07:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 305 L69 or LG4?
Following, in post #7, is a pic of the L69 dual snorkel set-up, the L69's most distinguishing feature:
https://www.thirdgen.org/forums/hist...e-85-iroc.html
The set-up above is on an LG4. Take note of the AC lines. If yours are similar, the car's an LG4 (The L69 lines wouldn't be seen as they dip down at the dryer). Also, IIRC, the L69 is equipped with an electric fan.
JamesC
Old Apr 6, 2010 | 12:02 PM
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
Re: 305 L69 or LG4?
Thanks for the info guys
Old Apr 6, 2010 | 12:24 PM
Engine: 383 Stroker
Transmission: t-56
Re: 305 L69 or LG4?
No problem. But of course you really asked this out of curiousity, because your really dropping in a 383
Old Apr 6, 2010 | 12:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
So, which do you have???
The tuning sticker under the hood may also give a hint. LG4 timing was 0 degrees, L69 6 degrees.
Old Apr 6, 2010 | 05:39 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 L69 or LG4?
Going by the air cleaner is silly because it's so easily swapped. L69s had ESC, while LG4s did not. This is a visible clue if it's there.
Old Apr 6, 2010 | 06:16 PM
five7kid's Avatar
'85-'87 LG4's did have ESC, so need to be careful there (although '86 L69's were rare, and there were no L69's in '87).
Old Apr 6, 2010 | 06:25 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 L69 or LG4?
Learn something new every day.
Old Apr 6, 2010 | 06:28 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Re: 305 L69 or LG4?
wasnt the only L69 on a 83 camaro come with a 5 speed?...wasnt that the only way u can get the L69 on the 83 camaro?...so is ur camaro a 5 speed stick?....
Old Apr 6, 2010 | 06:29 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 L69 or LG4?
No, the L69 could have the 700R-4.
Old Apr 6, 2010 | 08:24 PM
Car: 1983 Z-28
Engine: 5.7 L
Re: 305 L69 or LG4?
if im not mistakin u were able to get that in the newer camaros...from what i kno the 83 5 speed stick was the only camaro that year with the L69...guys plz do correct me if im wrong...
Old Apr 6, 2010 | 08:54 PM
JamesC's Avatar
Re: 305 L69 or LG4?
IIRC (and I may not), 84 was the only year for the L69 and an auto. I'd think a manual was available on all 305's, HO or not.
JamesC
Old Apr 6, 2010 | 09:55 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 L69 or LG4?
Some few years ago, I bought a totalled low-mileage, garage kept, one owner, numbers-matching '83.5 Trans Am, as a parts car, for $500 cash. It was a 700R-4. I took the engine, trans, rear, steering, & brakes, but the dual-snorkel was ruined when the car was totalled.
And the T5 was available with the LG4 in '83-'87
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Formula_88AE
Sep 3, 2015 01:47 PM
