trouble codes 23, 42 & 43
Old Apr 10, 2010 | 01:49 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
I own a 1991 Firebird Formula 305 V8 tbi. After driving the car for about 5 minutes i get the SES light. So i did the paper clip trick to pull up my error codes and ended up getting 23, 42, 43. what kind of solutions can i do to remove/fix these codes?
Old Apr 11, 2010 | 04:15 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: trouble codes 23, 42 & 43
Maybe it's time for a new Mustang?
Old Apr 11, 2010 | 07:30 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
I wonder why i didn't think of that first? Wait i do. It's like a people having a nose; everyone has one.
Old Apr 11, 2010 | 08:41 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello Foster382!!
Are these all new codes, or is there a possibility that there are some old ones???
If there is a possibility that some are old, I'd erase the codes first, then start up the car, and go for a drive, trying to reset the codes!!
Stop after you get a SES light, and check out which code it is!!
Post back your results!!
If these are all new codes, post back, and I'll see what comes up for you!!!
A new Mustang is not the answer!!!
Old Apr 11, 2010 | 10:10 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Well, if the guys who do know your answers won't tell you, maybe they're not guys you should call friends. Me, I don't know. When my LO3 developed problems with the injection, I couldn't get answers, so I just ripped out the entire TBI system.
Old Apr 12, 2010 | 06:35 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
87IROC-DAN61; i did what you said and i only got the code 23. I dont know how 42 and 43 went away; i never did anything to fin them besides replaced the. spark plugs lol. Would code 23 cause the SES light to come on after a few miles?
And if i did end up getting a mustang it would be an 88 Foxbody
Old Apr 12, 2010 | 12:16 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Sorry I wasn't very helpful before, you can see I haven't given up on third gens, just on helpful help with TBI. I currently have an '84 Trans Am, and an '89 Mustang. and I think everyone should have one of each. But for those who can't afford that, this is the better chassis to play with.
Old Apr 12, 2010 | 03:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A trouble code will clear after 50 (or some high number) ignition on/off cycles after last being set. Had you set the timing sometime in the near past?
The 23 should be the inlet air temp. Have you fussed with the air cleaner?
Old Apr 12, 2010 | 05:28 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Im not all that car smart. My auto-tech teacher said someone had advanced the timing abit on the car. I did spray throttle body cleaner on that sensor to clean it. Maybe it was to cold for it?
Old Apr 13, 2010 | 01:41 AM
Hello Foster382!!
Spraying anything, especially throttle body cleaner on a sensor is a no-no!! Sensor internals don't like liquid, nor solvents!! Spray the cleaner into/on to a rag, then use the rag to clean the sensors!!
Check for a broken/chaffed/disconnected wire to that sensor, if you can't find any, replace that sensor!!
Best of luck!!
Old Apr 13, 2010 | 02:02 AM
Hello again Foster382!!
The other codes could reappear shortly, or they could be gone for good, due to other factors, hopefully that is the case!!
Yes, code 23 could cause the SES light to come on after it goes into closed loop mode (after a few miles)!!
No Mustang!!
Old Apr 13, 2010 | 05:46 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
seeing that their are no wire to this sensor, just 2 vacuum tubes. can't i cap off the vacuum line?
Old Apr 13, 2010 | 11:16 AM
five7kid's Avatar
You aren't looking at the correct sensor. One has wires, the other has vacuum lines.
Old Apr 13, 2010 | 01:03 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Check here for info on the IAT, Intake Air Temperature Sensor.
https://www.thirdgen.org/forums/tech...r-element.html
five7kid, remember how I said I had no SES lights come on when I bought the car which later found out the IAT was unplugged, maybe because I only drove the car a little bit and it didn't have time to go into closed loop? It did have time to overheat and such but, maybe not long enough to pop the SES on?
Old Apr 13, 2010 | 01:59 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Isn't it kinda ironic that the Code 42 & 43 both have do with timing
42 Electronic Spark Timing or Bypass fault
43 Electronic Spark Control fault
Especially since he stated that someone playing with the timing on the vehicle.
Old Apr 13, 2010 | 02:23 PM
five7kid's Avatar
No, it's not ironic. It's why I asked.
Old Apr 13, 2010 | 04:54 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
well my TBI air inlet looks like this:
I only see the sensor for the vacuum lines.
Old May 31, 2015 | 09:06 AM
Chris67rs's Avatar
Car: 91 Firebird Formula WS6
Axle/Gears: 3.27 9 bolt
i know this is old but i had the same issue,
Code23 could be one of 3 things, mine was the first
1: TPS sensor malfunction
2: IAT sensor
3: Manifold Air Temp sens
tps was 13$ at autozone and 2 hex bolts and a wire. boom back in action.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
