Lost My 305 Today
Old May 3, 2010 | 07:45 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Lost My 305 Today
Went to accelerate, then I noticed the carb spitting out the air cleaner and had a engine clunk at 1/2 engine rotation speed. Still hitting, but also spitting out the carb and idled smooth... With the clunk.
I have been looking for motivation/inspiration to test fit my 500 Caddy/4l80 combo
Looks like I have a reason now.
Old May 3, 2010 | 09:21 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Lost My 305 Today
Way to have a valvetrain problem!!!!!!! Don't forget to post your 416s in the classifieds.
Old May 4, 2010 | 08:00 PM
Car: 1986 Trans Am
Engine: 5.0
When this happened, i had just worked a 12 hour day. I am now thinking it's nothing more then a slipped timing chain. Might have it torn down by tomorrow evening.
Old May 4, 2010 | 08:20 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I doubt the chain being a tooth off. These mid '80s chains aren't as bad as early 70s chains. They still stretch, but nowhere near as much.
Old May 4, 2010 | 08:45 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
they don't stretch, but the garbage plastic teeth still like to shear...
Old May 4, 2010 | 09:27 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Oh yes they do stretch. Dramatically. I've changed them on my own late '83 L69, and my own '91 LO3, among others.
Old May 4, 2010 | 09:44 PM
mw66nova's Avatar
Engine: 7.0L
sorry, i didn't quite type my whole thought process, lol...what i was meaning to type was "they may not stretch like the 70's chains, but the garbage plastic teeth like to shear more often"
Old May 4, 2010 | 09:50 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
ahh, gotcha.
Old May 5, 2010 | 06:55 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
I'm not sure why these engines don't have a tensioner, seems like that might be important. Are the teeth really made of plastic?
Old May 5, 2010 | 07:04 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
no, they're covered in nylon. And if you use a good aftermarket chain, you don't need a tensioner. I've seen a Manley double roller chain go 90,000 miles and have less than 3 degrees worth of stretch in it after all thaose miles. Similar story with Cloyes Street Roller sets I've used in my own engines.
Old May 5, 2010 | 06:14 PM
Car: 1986 Trans Am
Engine: 5.0
Yanked everything down to the timing chain. I see a double roller in excellant condition
The distributrer is exactly 180 degrees away from #1.
Tomorrow I yank the valve covers and take a peek. I can't imgine what is wrong now. The way the engine was spitting back through the carb, I would have placed a bet on the timing chain. Unless the coil was firing late for some reason.
Old May 6, 2010 | 02:28 PM
Car: 1986 Trans Am
Engine: 5.0
Is the any way the ECM could be causing late firing making the engine spit back up the carb?
•edit• nevermind, I forget about the noise
I think I shall name this engine "Toast"
Old May 8, 2010 | 05:39 PM
Car: 1986 Trans Am
Engine: 5.0
Old May 9, 2010 | 11:44 AM
Car: 1986 Trans Am
Engine: 5.0
My expert noob opinion is that a valve seat recessed causing thr pushrod to break. I noticed the top of the valve was higher then the others. Using a straight edge acroff the tops of the valves confirmed it.
Oh,well...time for a late model engine swap
Old May 9, 2010 | 06:29 PM
mw66nova's Avatar
Engine: 7.0L
i'm in favor of this notion.
Old May 9, 2010 | 08:21 PM
Car: 1986 Trans Am
Engine: 5.0
Unfortunatly, this needs to be done asap as this car is my DD. So this might go carbed out of convience.
Infested
May 22, 2018 11:56 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Jae992
Aug 27, 2015 09:07 AM
2QUIK4U
Aug 26, 2015 04:40 PM
spaigo
Aug 21, 2015 07:46 PM
