what type gas do you use?
Old May 13, 2010 | 11:36 AM
welchk85's Avatar
Car: 1990 camaro rs 3.1 v6
Engine: 3.1 v6
i have the v6 3.1 and i normally use regular gas 87 "proof" what type does everyone use? should i use 89 or 91 or should i jsut stick with 87?
Old May 13, 2010 | 12:26 PM
350Irocz28's Avatar
Re: what type gas do you use?
87 is good for your V6. I run 93 in my camaros because they are both running on tuned prom chips.
Old May 13, 2010 | 12:40 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
I would run 91 when I had my bird on the road also because of a chip... once a month I would use octane booster... I swore I could feel a little edge, but hmm... not for sure... ..
Old May 13, 2010 | 12:48 PM
welchk85's Avatar
Engine: 3.1 v6
Originally Posted by 350Irocz28
87 is good for your V6. I run 93 on my camaros because they are both running on tuned prom chips.
do you think there would be a noticible difference if i went to 91? hmmm prom chips ive been thinking about doing that if was to do that what would be the best one to go for? im also thinking about doing a homemade ram air. and im gutting out the cat this weekend because its clogged all to hell and im to broke for a new one and is there a noticible difference with the chip? how much more power did you get?
Old May 13, 2010 | 01:35 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If the car runs fine on 87, switching to a higher octane won't make any difference.
Old May 13, 2010 | 01:48 PM
350Irocz28's Avatar
I put a corvette chip in my 89 LB9, all I got was better throttle response. Then in the 89 L98 I had one with a mild tune, I got quicker acceleration. I'm not sure it'll make a v6 camaro quicker.
Old May 13, 2010 | 01:51 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Yeah, it all depends on what the car is tuned for. A higher octane won't help unless your car is setup for it. I believe the rating for my little 305 tbi is ~88.5. I gotta double check my owners manual on that.
welchk85's Avatar
Engine: 3.1 v6
i should have worded it better i dont really care if it goes "quicker" i dont even personally care if it goes over 90mph lol i just want it to get to 90 like NOW haha
Old May 13, 2010 | 02:57 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
a chip will simply give you different fuel curve and a bit more timing... you'd have to do some research to see what is "ACTUALLY" available for a v6... probably look for a shop that deals with tuning....
I was going to say PCM4Less, but a member here on TGO, had a bad experience, and they were kinda' giving him a hard time about what was actually wrong with the chip.. from what I've read they eventually said send it back.. but member had already solved the issue through a different party.. so if you go with them, just keep in mind I am not recommending it ..
Old May 13, 2010 | 03:06 PM
thedrewdotcom's Avatar
Car: 1986 IROC
E-30.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
Hello, Michael
Sep 11, 2015 01:10 PM
