Oil Viscosity Question?
Old May 23, 2010 | 07:08 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Hi there..
I have seen a LOT of this oil threads but still I ain't sure about what oil to choose on my engine. Just wanted to hear some opinions:
I have a newly rebuild 87 305 TPI engine which have some modifications such as cam, headers, new pistons etc.etc.
The car is used most summer and spring time and not in the winter.
I know that the stock oil viscosity rating should be about 5w-30 and I also now that 5W is the oil "thickness/weight" on cold starts so basically that one doesn't matter as much since I am going to use the car mostly summer time.
I am just a little bit unsure on the "warm" engine oil viscosity like the 30 number on this oil type. The oil stores around here in Norway have 5w-30 synthetic oils but they are the most expensive oils. So my question is could I buy for example 5w-40 and run that on my engine?
I want to use synthetics since the engine is freshly newbuilt.
Are here any oil-experts that could give me an advice?
By the way I have drove about 1000miles on regular 10-40 mineral oil under the engine break in period. So now I want to change the oil and filter and use synthetics from now on...
Old May 23, 2010 | 09:52 PM
CrAlt's Avatar
Car: 83 TA
Engine: goodwrench 350
Re: Oil Viscosity Question?
Originally Posted by camaro87-alex
Hi there..
10w30 is what I would use.
Old May 23, 2010 | 10:15 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
I use Castrol GTX 10w30, and that's what I suggest you use, I have to agree with cralt.
Old May 24, 2010 | 06:28 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
I woulndnt use synthetic till the motor was broke in, and I would use mobil 1, yes it cost more but if you want REAL synthetic use mobile one. See here in the usa oil is not regulated like in say germany. Int the usa we can make oil mix it with a little synthetic and call it that. But in germany the are very tight on emmisions and the oil that is sold as synthetic is 100 percent real and can you guess that there is only one true 100 percent synthetic oil? yep mobil one, if you have doubts go look it up. but that is the only oil i will ever use......
Old May 24, 2010 | 01:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is the 5W-30 more expensive than the 5W-40?
A 5W-30 would be fine. Not all synthetics are created equal, so without knowing more details, it's hard to say much more than that. Typically, though, it's better to keep the spread between the two numbers as small as possible. A 30 weight is all you need for warm temperatures, but all else being equal, a 10W-30 would be preferred to a 5W-30.
Old May 24, 2010 | 01:03 PM
five7kid's Avatar
Originally Posted by game1939
I woulndnt use synthetic till the motor was broke in...
Sounds like that's covered.
Old May 24, 2010 | 04:45 PM
game1939's Avatar
Engine: 383
with 5w30 you will get better gas milage,
Old May 24, 2010 | 05:26 PM
one92rs's Avatar
Car: SOLD!!!!!
actually the engine oil is a 30w viscosity when it is cold and then the 5w viscosity when the engine is hot. from all the reading i have done and experiences as being a mechanic i use a 10w-30 all year round. but i live down south.
Old May 24, 2010 | 05:32 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
i use 20-50 on my bolt on 350tpi
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
