cam too big?
Old May 23, 2010 | 08:17 PM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
cam too big?
i got a 350 to replace my 305, it's all rebuilt and it comes with this cam in it http://cranecams.com/index.php?show=...92&lvl=2&prt=5
but i was told this cam is too big for a street car, should i get something smaller? or use it and get a high stall converter?
Old May 23, 2010 | 08:57 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: cam too big?
that depends on the heads, compression, intake, etc. you will likely need 2500 stall or so.
Old May 23, 2010 | 09:31 PM
camarito's Avatar
Re: cam too big?
for heads it has a set of 882's poted with stock valve size but they look like they were milled, the guy a got the engine from didn't know anything about it, and the block has flat top pistons but i might get a set of aluminum Vortec heads
it also came with a Weiand tunel ram intake but i'll be using the Edelbrock RPM intake i have on the 305 (if i don't get the Vortec's)
Old May 23, 2010 | 10:12 PM
Re: cam too big?
you have the right idea. get the vortecs.
Old May 23, 2010 | 10:34 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: cam too big?
Way too much cam... Won't start working till around 3,000 RPM, a bit high for the street. A higher stall converter would help, but a higher stall speed means more slippage, slippage translates to heat and another problem for street usage. I suggest a much milder cam.
I'd also suggest getting all the details on your heads and pistons, then armed with that check out the cam selection software (free download) on the Comp Cams website. If you input accurate information concerning your engine and the rest of the car it will provide a very accurate recomendation for what cam will give you optimal performance.
But then, if you just want one of the "poser cams" that sounds kewl but performs like poo poo, the crane cam you've linked to would be acceptable!
Old May 25, 2010 | 05:42 PM
camarito's Avatar
Re: cam too big?
No i'm not looking for no "poser cam" but a nice slightly loppy sound yes, something on a 110LSA, but i guess i need to get the heads first then
Old May 25, 2010 | 06:00 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: cam too big?
In a perfect world, the heads determine the cam.
Old May 26, 2010 | 07:14 PM
camarito's Avatar
Re: cam too big?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
are this ones any good?
the price is pretty good, i'll be doing some side work, a cam swap on a 5.7 hemi, it might pay for this
Old May 26, 2010 | 07:52 PM
hawkins's Avatar
Re: cam too big?
the lift is not too big it's the duraation you want to watch out for.mine is a 218/228/.525.525 and runs good
Old May 26, 2010 | 09:57 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Re: cam too big?
Rather then just guess on a cam or go by 2nd hand information on how it worked in someone else's engine that is probably totally different from yours you might want to check out Comp Cams "Cam Quest" software...if you put in correct information it will recomend the cam and other valve train components necessary to make the engine work right!!! Heck, it's even a free download!
Old May 27, 2010 | 12:12 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: cam too big?
[QUOTE=radical82;4554892]Way too much cam... Won't start working till around 3,000 RPM, a bit high for the street. A higher stall converter would help, but a higher stall speed means more slippage, slippage translates to heat and another problem for street usage. I suggest a much milder cam.
QUOTE]
Jake
Old May 27, 2010 | 01:39 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: cam too big?
What the hay. Put on the performer RPM, a 2550 stall converter and run it. See how it works. If you dont like it. You can always change it later.
Old May 28, 2010 | 10:19 AM
steNcho's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 355 SBC
Transmission: TH350 with 3500 stall
Axle/Gears: GM 12-bolt with 4.10 gears
Re: cam too big?
Running a 242, 248 at .050 solid roller with .570, .576 lift. Idles and runs fine on the street. 3000 stall converter, stock radiator and flex-a-lite 180 fan in 95 degree weather all year and no overheating what so ever. This cam was a great fit in comp cams software .
Old May 28, 2010 | 12:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: cam too big?
The cam that comes in your 350 is a 228/234, and i'm assuming hydraulic flat tappet. I didn't notice the LSA listed? I don't recall off the top of my head how to calculate it either (lil help?)
That's very similar to the compxe268HE (had it) or the Lunati 60103 (had it). All excellent cams. You need high compression and a bigger stall speed. 3000RPM stall speed and Vortec heads and that'd be a BLAST.
I had those cams with ported 416 heads and a T-10 tranny. Very fun car.
I'm a big fan of big cams though, I don't drive to buy groceries in this car though, so a daily driver might be annoying. I found 24* base timing, 36* all in, with about 14* of vacuum advance at idle worked best. No vacuum reservoir required for brakes.
10:1 CR is a good thing too, FYI.
Old May 28, 2010 | 01:33 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: cam too big?
Please dont anyone laugh but I run 240/240 @050, 112 lsa, 560/560 hyd. roller with a 2,300 stall converter. Tried a 3,500 stall and hated it. This car drives very nice on the street and is scary fast.
Old May 28, 2010 | 01:39 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: cam too big?
I took a look at comp cams cam matching software. It didnt list my cyl heads (Trick Flow Twisted Wedge) nor did it list any option for modified TPI intake. I dont see how it could accurately match a cam to a combo like mine. Was I missing something?
Old May 28, 2010 | 02:27 PM
steNcho's Avatar
Engine: 355 SBC
Re: cam too big?
Looks like a nice combo doc. Most people are too scared of losing drivability and don't try out stuff. So lots of people would say certain things are too much for the street. If you want good gas mileage, v8's aren't for you. If you wanna have as much fun as possible, try stuff out before saying it's too much.
Old Jun 5, 2010 | 11:00 PM
camarito's Avatar
Re: cam too big?
well i decided to run it, I'll get a 2400 stall and a set of Procomp heads will see how it runs, by the way this cam is on a 106 LSA so it's going to sound nice
Old Jun 11, 2010 | 08:23 PM
camarito's Avatar
Re: cam too big?
OK, the ProComp heads got here today 210cc intake runners 2.05 intake valves, 1.6 exhaust 64cc chambers but they came with dual springs for a roller cam up to 650 lift, can't use that on flat tapets can i?
Old Jun 16, 2010 | 06:47 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: cam too big?
These roller springs will work fine with a flat tappet cam. The reason for specifying "roller springs" is that aggressive roller profiles can cause failure of "non-roller" springs. The difference is silicone content in the spring alloy.
A high performance roller cam has much faster ramps, meaning that it opens and closes the valve much more quickly than a flat tappet cam of similar duration. This is why a roller cam, of a given duration, can produce significantly more power than a flat tappet cam.
For your own information, compare lift numbers on your flat tappet cam choice with lift numbers on a hydraulic roller cam of about the same duration. Youll find that the roller cam's lift numbers are significantly higher. You can also set the two cams beside each other and see a noticeable difference in the lobe profiles. The flat tappet lobes will be egg shaped with small lobe tips while the roller lobes are more oval with large round tips. The tip of the lobe is where the valve is fully open. A flat tappet couldnt follow these aggressive roller lobes but a roller tappet can follow any shape.
The lobe profile of a flat tappet cam is limited by the size of the tappet surface about 13/16". The cam lobe has to run on that circle without touching the edge. Hydraulic roller cam profile is limited somewhat by the weight and the pressure capacity of hydraulic tappet but still gives the lobe designer much more freedom.
My point if you havent already guessed it is, why would anyone, class racing rules aside, waste their time building an engine with a flat tappet cam?
Old Jun 16, 2010 | 07:53 PM
camarito's Avatar
Re: cam too big?
things have changed a little i have a Comp Cams XE284-10 and yes the springs are perfect for it, Comp recommends 322lbs and the ones on the heads are 325lbs i just have to remove the inner springs during cam brake in.
I was thinking about the roller cams but can't really afford it right now, I'm not going to put the engine together yet so if i do another side job i might still consider the roller stuff but for now flat tappets are the plan and for the price i can change cam and lifter once a year
Old Jun 17, 2010 | 10:30 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: cam too big?
Yeah, I come off kinda strong on the subject, I know. Ive built plenty of flat tappet motors for NASCAR guys. Some classes require flat tappets. I know that retro rollers can be pricey too. Im sure youll have fun with this motor and it will run like the devil.
Just remember, for any given idle quality, a roller cam will give you way more tire smoke. LOL. Good luck man
Doc
Old Jun 17, 2010 | 10:56 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: cam too big?
Hey, Sorry if I come off a little strong on this subject. Ive built plenty of flat tappet motors. Mostly for local NASCAR guys whos class rules require flat tappet cams. I also understand how pricey retro rollers can be. Im sure your motor will be alot of fun with the XE 284.
BTW, I use Oregon Cam Grinding and have all my cams custom ground. With cam and lifters I save about 30% off Comp Cams prices. You might want to check out a local cam grinder in your area. Ive been real pleased with the results from Oregon Cams. They can reproduce any grind you want and will give you a cam card like you wont get from Comp.
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
BOOT77
Sep 5, 2015 03:55 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
