lt4 hotcam with tbi
Old May 26, 2010 | 06:43 PM
my84camaro's Avatar
lt4 hotcam with tbi
would a lt4 hotcam with a stock 95 350 tbi give good lower end and top end?is it a good choice
Old May 27, 2010 | 09:23 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: lt4 hotcam with tbi
NO. The problem is the heads. those heads are the dreaded "swirl-port" version, and they do not flow. Get some better heads before considering a cam.
Old May 27, 2010 | 09:25 AM
my84camaro's Avatar
well the heads I have are stock from a 88 camaro 5.0
Old May 27, 2010 | 09:29 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
still terrible heads. They dont flow enough to make much power. Will not work good with that cam
Old May 27, 2010 | 09:31 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
there were 2 different designs used in '88 on the 305s. The TBI 305s were also swirl-ports. Only the TPI 305s had decent heads, casting number ends with "081"
If you have those, then you're ready for more cam. The HOT cam isn't a bad choice.
Old May 27, 2010 | 09:34 AM
my84camaro's Avatar
they are from a tbi motor
Old May 27, 2010 | 09:35 AM
my84camaro's Avatar
so I should just put the stock 305 roller cam in the 350 for now
Old May 27, 2010 | 09:36 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
I'm forever told that stock TBI heads can't do more the .480" of lift, though no one has ever elaborated why or how to fix this issue. With 1.5 rockers, a LT4 Hot cam would have .492" of lift. Also, the intake and exhaust ports on a LO3 swirl port are flow saturated at .400" of lift so reaching for a cam with .500" or more of lift really wouldn't pay dividends anyway.
Old May 27, 2010 | 09:37 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
No, that's the worst cam there is. Do you have the cam that came with the 350? Cause it's better and you should stick with that.
Old May 27, 2010 | 09:41 AM
my84camaro's Avatar
just the assembled block,no heads cam or lifters.on my 88 camaro I was just going to swap out the 305 for the 350
Old May 27, 2010 | 09:42 AM
my84camaro's Avatar
would a stock lt1 cam work?
Old May 27, 2010 | 09:47 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Yes, that's a good cam to use. A regular LT4 cam is a good choice as well. Also a 350 Ramjet cam.
Old May 27, 2010 | 02:08 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
No, the OP has too much SCR for the RJ cam.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
