NEED HELP PLEASE timing
Old Jun 14, 2010 | 01:37 AM
64elko's Avatar
Car: 64 elcamino
hello
what's happening is my timing keeps advancing ,,I set it at 6 BTDC..drive it 50 miles and the temp gage is 200 +,,check timing and it has advanced 14 degrees BTDC.. buy it self....I replaced every sensor on the motor..checked fuses check all grounds everything on this car is new..everything on this motor is matched for an 86 305 TPI... i cant keep driving my car to work like this to work and home ,MUCH LONGER IT'S MY ONLY FORM OF TRANSPO,PLEASE PLEASE I NEED HELP... A.S.A.P.
Rick
Old Jun 14, 2010 | 01:50 AM
1990z28's Avatar
Car: 1990 Z28 Camaro
Re: NEED HELP PLEASE timing
When you set your timing did you unplug the thing thats on passenger side near hood strut. If so when you set timing thats with that unplugged when you plug it in your computer will advance the timing I set mine a 0 and its running at 12 with it plugged back in. I hope this is some help.
Old Jun 15, 2010 | 12:35 AM
64elko's Avatar
Car: 64 elcamino
hello
yes i unpluged the timing for the ecm to set timming,,, retarded it to zero ,ran ok on the way home ,,checked timing it was 14BTDC.... still same problem.... an i have NO check light coming on... i keep my timing light in my car now...
Old Jun 15, 2010 | 12:40 AM
1990z28's Avatar
Is it running bad at all or is it running good. Only thing I can think of if its running bad is to set timing a few negative degrees and if it goes back that high its just the way the computer whats to run the timing for it. Thats the only thing I can think of.
Old Jun 15, 2010 | 12:43 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
with the EST unplugged you set your timing to specs either TDC, 6 or 10... then you plug your EST back in and your timing should advance ... only check your timing with the EST unplugged, this is the timing that is considered your base timing and is the only way to check your timing with a timing light ..
Old Jun 15, 2010 | 01:13 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
And when you plug the EST back in after setting base timing, turn the car off, and remove the negative battery cable for 30 seconds. As it clears the computer, then when you reattach the negative cable the computer has proper timing, and adjusts it accordingly.
Old Jun 15, 2010 | 07:51 AM
64elko's Avatar
Car: 64 elcamino
hello stangski
ok i will try it berfor work and check when i get to work...well let you know what happend....
Rick
Old Jun 15, 2010 | 07:54 AM
64elko's Avatar
Car: 64 elcamino
HI Stangski says do the same thing but un hook the battery when done to clear the ECM ,,so i will try it and let you guys know..thank you..
rick
Old Jun 15, 2010 | 09:39 AM
Stangski09's Avatar
Yes, that's how you set proper base timing.
Old Jun 15, 2010 | 05:24 PM
64elko's Avatar
Car: 64 elcamino
hello
yes i knew how to set base timing,,,i reset it and unhooked the battery terminal for 30 seconds and my car is running again ,,like it should... thank you...
Stangski09's Avatar
She runs good now?
Good Job!
Old Jun 15, 2010 | 07:38 PM
64elko's Avatar
Car: 64 elcamino
yes runs strong now,,,thanks
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
