sticking throttle?
Old Jul 17, 2010 | 12:58 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
sticking throttle?
OK, I have a 91' 350 tpi. I want some opinions on this issue. My throttle has been sticking now for a few months. So, a while back I installed a return spring on the stock throttle body. Ok, so everything fine for almost a year now. The other day the throttle started sticking again. Car can idle by itself in drive and go 25 mph. So, i need to know this: Is it a bad throttle body or just a bad accelerator cable? Someone please let me know. Thnks again
Old Jul 17, 2010 | 01:08 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: sticking throttle?
the throttle cable tends to fray at the ends and not in the tube check for carbon build-up in the throttle body spray it down with cleaner and see if that frees it up if not than it is more than likely the TB.
Old Jul 17, 2010 | 01:27 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Are you positive the throttle is sticking? When the engine revs high like you say, pull the car over and look at the throttle. If it's actually off the idle screw, then yes, replace the throttle cable. If it's not, then it's your IAC. These are the exact symptoms I had when my IAC went bad.
Old Jul 17, 2010 | 05:05 PM
ninetyone's Avatar
Axle/Gears: 3:42
Hey man, you say the Iac valve? Isn't there a way to reset it or set it? How can I test it to be sure? I have a voltmeter. I went out today and greased the throttle body up, on the spring looking part of course that hold the butterfly that the cables connect to. I even shortened the return spring that I have been using now for a few months. Still no go. Let me know what you think.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
Scorched1984
Sep 15, 2015 03:42 PM
banksGTA
Sep 13, 2015 11:56 AM
Randomtask2
Sep 7, 2015 05:06 PM
