temp raises slowly but surely.
Old Jul 27, 2010 | 01:58 AM
91nunifb's Avatar
hey everyone,
im a noob on this thread (and everything firebird). I recently got a 91 firebird 5.0 . the car runs amazingly, but it heats up slowly but surely. going from about 140 to 220 and over if i drive about 4 to 9 miles. I noticed the reservoir tank boiling over, so I burped the system and replaced the rad cap (it was in horrible shape). The temp still kept going up slowly but got to around 180 if im not mistaken. I just really want to know if the way it heats up is normal for our cars or if its just mine being stupid. thanks a million in advance.
Old Jul 27, 2010 | 07:47 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: temp raises slowly but surely.
Normal op temps for these cars is about 220. You can lower those temps by swapping in a 180 thermostat and by replacing the factory fan switch located inthe pass side head with a cooler switch. There should also be an air dam located under the car mounted right under the radiator - if it's overheating on the highway then make sure there is that air dam there. Is this a TPI (tuned port injection) or a TBI (throttle body injection) car? TPI has an injector for each cylinder, TBI has what looks like a carb on top but it has 2 injectors inside.
Old Jul 27, 2010 | 12:54 PM
91nunifb's Avatar
I want to say its TBI. The airfilters are different no?
Old Jul 27, 2010 | 12:57 PM
Car: 1992 RS
Engine: Carbed 350
TBI has what looks like a normal old school air filter - round.
Old Jul 27, 2010 | 01:02 PM
91nunifb's Avatar
yea thats it.
Old Jul 27, 2010 | 01:16 PM
Car: 1992 RS
Engine: Carbed 350
OK. Make sure it has the air dam underneath the rad. These cars run hot - GM's brilliant method of reducing emissions. Most of us like them to run cooler. I never had any luck with the factory style fan swithces - even expensive aftermarket ones crapped out on me all the time. I went with a seperate fan controller - it's fully adjustable, easy to wire in, works with A/C, and can have a seperate toggle if you like. TBI car fan is independant from the computer, so that's why I asked - you can use a seperate fan controller with no computer issues if you ever decide to try that route - they run anywhere from $35 to over $100 depending on the bells and whistles.
I not saying you need one, just offering my experience. But 220-230 is not unusual i these cars.
Old Jul 27, 2010 | 01:17 PM
91nunifb's Avatar
what does the dam look like? I was looking under and there doesnt seem to be anything that would force the air into the rad
Old Jul 27, 2010 | 01:21 PM
Car: 1992 RS
Engine: Carbed 350
Should be black plastic, bolted right under the radiator, about 4 inches tall, about 3 ft across maybe. It'll be right under the radiator. It actually doesn't force air into the front of radiator, but creates a low pressure are behind the radiator - this low pressure area creates like a vacuum effect that draws air in through the radiator.
Old Aug 5, 2010 | 05:15 PM
91nunifb's Avatar
so, I do have the air dam, and I have switched out the rad cap. next step would be the thermostat. but after replacing the rad cap, the coolant still boils in the reservoir. the temp gauge went up to about 260 degrees. so that has me worried. any ideas?
Old Aug 5, 2010 | 05:33 PM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
260's the majic "don't do it, if you have don't do it again" number. Sounds to me like a cloged radiator. Try flushing it but I dought that will get it done at this point you may have to take it to a radiator shop to get cleaned out, or get a new radiator if it is clogged. Pull the cap off and see if it looks real crusty you will see what looks like scales growing in the radiator and possibly nasty looking coolant.
~Couch
Old Aug 5, 2010 | 06:04 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I haven't seen any mention in this thread yet about what the fan is doing through all of this. Is it even working, and when? Sounds a little like PO had a fan problem and possibly removed thermostat ?
Old Aug 5, 2010 | 06:06 PM
91nunifb's Avatar
yea it is working. Im gonna check again in a bit, just to be sure, but yea last time i checked its running.
sheachopper
Jul 31, 2019 11:27 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
