Throttle sticking
Old Aug 16, 2010 | 12:17 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Throttle sticking
Ok, here is the deal. My 1991 tpi 350's throttle feels like it is sticking. This only happens after a long trip or two or three WOT runs. Could it be a bad throttle body? or is it a bad cable? I cant decide.LOL. I also thought since it only happens under conditions that produce heat like a long trip or WOT that it could be the coolant flowing through the throttle body. Any ideas anyone??
ninetyone's Avatar
Axle/Gears: 3:42
Re: Throttle sticking
What I mean by sticking is that the car stays in each gear way way too long.
Old Aug 16, 2010 | 12:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Late shifts would be a transmission problem, not a throttle body problem.
Old Aug 17, 2010 | 05:15 PM
ninetyone's Avatar
Axle/Gears: 3:42
What is the little valve or the thing on the trans where my tv cable hooks onto called? I think the prob IS in the transmission. I see a little fluid or oil leaking from that little valve.
Old Aug 17, 2010 | 05:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Throttle valve linkage?
Old Aug 17, 2010 | 05:37 PM
ninetyone's Avatar
Axle/Gears: 3:42
I guess, I have to back under there and look again. I am assuming that is what it is. It is under the driver's side on the transmission.
Old Aug 17, 2010 | 05:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It could be a sticking throttle valve, they do that sometimes.
Old Aug 17, 2010 | 05:59 PM
ninetyone's Avatar
Axle/Gears: 3:42
Well, it only does it in the 1 to 2 shift. Using drive 1 and 2 is fine. Isn't the car quicker when you leave it in drive though?
Old Aug 17, 2010 | 06:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I doubt you'd even notice a difference.
Old Aug 18, 2010 | 07:07 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Sounds like the line pressure in the tranny is too high. Have you tried adjusting the tv linkage?
Old Aug 19, 2010 | 10:01 AM
ninetyone's Avatar
Axle/Gears: 3:42
It is a little high, but it has been that way for some time now and just recently did it start getting stuck between gears when in the d position and shifting into second under WOT. The car just doesn't feel as powerful and doesn't chirp tires with the tv cable adjusted to softer position.
Old Aug 19, 2010 | 10:05 AM
ninetyone's Avatar
Axle/Gears: 3:42
How do you adjust the tv linkage? you are talking the linkage on the trans itself right? I did adjust the linkage on the throttle body. Pushed in the cable as far as it would go and then held open the throttle to WOT. and let it adjust itself 3 clicks. Feels about right. Still gets stuck when i leave it in the drive position at WOT , only between 1 st and second gear though. If you let up slightly on the gas when this happens it will finally shift. Like i said , it didn't start this until recently, regardless of the tv cable.
Old Aug 19, 2010 | 11:03 AM
are you saying under normal driving conditions, your tranny doesn't shift into 2nd when it's supposed to?
Old Aug 19, 2010 | 12:18 PM
ninetyone's Avatar
Axle/Gears: 3:42
No, I am saying only at WOT,with the car;'s trans in the regular drive position. It goes click,click, click, clunk and just seems stuck! LOL. In the drive 1 and 2 it shifts fine under WOT, the rear slides sideways like it should!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
Scorched1984
Sep 15, 2015 03:42 PM
banksGTA
Sep 13, 2015 11:56 AM
Randomtask2
Sep 7, 2015 05:06 PM
