Engine Stalls
Old Aug 21, 2010 | 07:12 PM
F1 Bomber's Avatar
Car: 85 Trans Am Iroc-Z
Engine: 305 H.O. 4bbl
Transmission: 5 Speed
Axle/Gears: 3:73 Posi-trac
Engine Stalls
Hey there, So I have a 85 T/A with the 305 H.O. 4bbl. When I go to start it up after it has been sitting for 6+ hours, it likes to stall right as soon as it fires up the first time and then again the second time unless i give it a little gas and keep it at 1000 rpm for a minute. After that its good until I let it sit for a 6+ hours again. I used a carb and choke cleaner but nothing. Any suggestions?
Old Aug 21, 2010 | 07:24 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: Engine Stalls
Do you pump the peddle before starting? Is your choke closing?
Old Aug 21, 2010 | 07:50 PM
F1 Bomber's Avatar
Re: Engine Stalls
No I dont pump the peddle, and the choke isn't closing.
Old Aug 21, 2010 | 08:26 PM
Re: Engine Stalls
Try pumping the peddle four or five times and start. Repeat two or three times. See what happens. Pump to the floor.
Old Aug 22, 2010 | 09:24 AM
Re: Engine Stalls
I am curious to know if your car started as it should?
Old Aug 22, 2010 | 01:03 PM
F1 Bomber's Avatar
Re: Engine Stalls
I tried pumping the peddle and it didn't seem to do much, still stalled, I am going to give the choke another check once it stops raining.
Old Aug 30, 2010 | 11:13 AM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
Re: Engine Stalls
I have the same starting issue on an 87 firebired 2.8 V6, But it will also die randomly while driving. Regardless of outside temp.
I just pulled a code 34
Last edited by thunder69n; Aug 30, 2010 at 11:31 AM. Reason: put wrong year its an 87
Old Aug 30, 2010 | 11:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine Stalls
Shouldn't need to pump it more than once. Twice in cold weather.
Old Sep 2, 2010 | 12:43 PM
thunder69n's Avatar
Re: Engine Stalls
on mine changed
Mass airflow sensor
o2 sensor
pcv valve
spark plugs
no luck still starts like ****
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
Bryan F
Aug 18, 2015 02:28 PM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
