new cam install problem! help quick!
Old Sep 1, 2010 | 02:31 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
hey guys
so im in my garage r8igh now putting ym engine together and i got my new lt1 style (i have a tpi) comp cam in thhere and the dowel pin wont let the timing gear line up corrrect, do i need to pull the pin out or am i boned???
Old Sep 1, 2010 | 02:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: new cam install problem! help quick!
The dowel pin won't let the timing gear line up any way but correctly.
Old Sep 1, 2010 | 02:39 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
its pushing it like 1/4 in to far to one side of all the holes
Old Sep 1, 2010 | 02:41 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Old Sep 1, 2010 | 02:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're using the wrong timing set.
Old Sep 1, 2010 | 02:56 PM
alek72us's Avatar
Car: 1991 Camaro z28
Engine: TPI 350
Transmission: Auto 700-4r
Axle/Gears: 3,23
Old Sep 1, 2010 | 02:59 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
god damnit, really starting to hate these speed shops, my oil pickup is wrong to
Old Sep 2, 2010 | 10:59 AM
squatingeagle's Avatar
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.23 posi
"for lt1 or l98 engines (pre 1996) the dowel pin in the end of the camshaft must be pushed in so extension from end of cam is .30"+-.01". for 1996 lt1 and lt4 engines, the dowel pin is in the correct position extending .620" from the end of the camshaft"
straight out of GM Performance Parts catalog. hope this helps
Old Sep 3, 2010 | 11:35 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
You have the wrong timing set. you need a timing set for a 87+ engine, that is cleary a timing set for a 86 and below flat tappet engine.
84z96L31vortec
Aug 20, 2017 12:16 AM
happyhapka
Aug 15, 2015 04:42 PM
TheJoeY88
Aug 13, 2015 06:51 PM
Fronzizzle
Aug 9, 2015 01:15 PM
