Starter Trouble
Old Sep 22, 2010 | 04:03 PM
Demand570's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI Injection,Edelbrock intake,
Axle/Gears: 89 Trans-Am 3.42
Starter Trouble
92 Camaro starts sometimes,then go to restart , turn key and nothing,its like theres nothing there,lights dont dim,gauges dont jump,is it selenoid stuck,or maybe broken wire ,?
Old Sep 22, 2010 | 04:14 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Starter Trouble
Well, what is happening when you turn the key and it won't start. What noises is it making? Is it a single click? If it is , then try and turn your key into the off position , then try and start it and you should get a click, then try that over and over again. It should eventually start. If you are getting a single click everytime you try and start it then I am willing to bet that it is a bad wire from the starter to the NSS.
Old Sep 22, 2010 | 11:19 PM
Demand570's Avatar
Car: 1992 Camaro RS
Re: Starter Trouble
Hello,thanks for the help,but it does nothing,like it isnt even hooked up,no power to it,but I went back an 1hr later and it started just fine again,everyone says its a broken wire ,or short,but what else is there,like from ignition,where does the power go from there to the starter,is there more to look for,thank god for this site,its helped me greatly,thanks
Old Sep 22, 2010 | 11:29 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
Re: Starter Trouble
sounds like i had the same issue with my 89 trans am. it's like your battery isn't even hooked up right? and just randomly it'll start just fine?
i took my battery out and brought it down to autozone where it was purchased to exchange for a new one, because at one point it was completely dead. they said it was fine, put it on a charge for an hour and cleaned the posts, since then, i had no problems with starting.
Old Sep 22, 2010 | 11:40 PM
Demand570's Avatar
Car: 1992 Camaro RS
Re: Starter Trouble
Hi,thanks,but no ,the battery is fully charged,when the lights are on and i turn the key,they dont dim,gauges dont jump,but all the startup lights come on,just no crank from starter,during the day tommorow im goin under and check wiring again,,,,,,do you know anything about th400 trans?need help there also
Old Sep 23, 2010 | 12:35 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Starter Trouble
starter circuit diag: http://www.austinthirdgen.org/index.php?pid=38
Old Sep 23, 2010 | 01:28 AM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
Re: Starter Trouble
Check the neutral safety switch.
Old Sep 23, 2010 | 08:17 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Starter Trouble
Is the security light illuminated when it won't start?
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
mrbird
Oct 20, 2015 03:43 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Lmancha96
Sep 25, 2015 08:11 PM
