Hard start, chug-chatter-stumble on hard accel under 3500ish
Old Sep 23, 2010 | 02:30 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
hard start, just replaced starter. sometimes backfires thru TBI when wont start after letting key go, white smoke smells like gas.
recently replaced alternator, starter, batter, ignition control module, ignition coil msd 8226, rebuilt tbi., spark plugs, plug wires, distributor cap and rotor, oxygen sensor
odd chatter/miss started after installing a tbi spacer. made few adjustments, seemed to get worse. I removed tbi spacer, same problem exists
adjusted tv cable, checked tps, reads .66v. this is a non adjustable tps, and has given me trouble free operation for last 4 years, it came with car/tbi
under hard acceleration, or acceleration under 3000-3500 car seems like its missing bad or trans/ converter not engaging. transmission rebuilt 30,000 miles ago, new torque converter at same time. plug wires are not arcing or shorting, pulled dist cap and there were deposits on the metal terminals in cap, scraped that off, no changes
if my tv bracket was tweaked a little bit could this cause all this drama? by tweaked I mean like 1-2mm difference
Old Sep 23, 2010 | 02:48 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: Hard start, chug-chatter-stumble on hard accel under 3500ish
You got it timed?
Old Sep 23, 2010 | 02:52 PM
Camarillo's Avatar
Car: 1990 RS Camaro
I have not adjusted or checked timing
timing has not been adjusted in 2 years, no settings were changed, never pulled distributor, It would not automatically change right?
Old Sep 23, 2010 | 11:54 PM
slowpoke's Avatar
Car: 1987 Z28
Axle/Gears: 273 Limited Slip
Try putting the stock coil back on. See what happens. Couldn't hurt.
Old Sep 24, 2010 | 12:08 AM
Camarillo's Avatar
Car: 1990 RS Camaro
will try this, could it be my distributor?
Old Sep 24, 2010 | 02:42 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Remember, if you change something, and you've got a problem where you didn't before, something you did most likely caused it (Lol the story of my life with my engine swap!!)
It's possible that any one of the new parts you put in are bad. I'd start by putting in the original cap, coil and rotor..and ignition module if you've got it. If the problem goes away, you just narrowed down the result. Also, since you did put a new cap, coil and rotor in, it's possible you bumped the distributor so it may not be a bad idea to double check the timing.
Old Sep 24, 2010 | 01:30 PM
Camarillo's Avatar
Car: 1990 RS Camaro
slowpoke, pm me your mailing address, I have some paper for you! It was the msd 8226! 38 days old and it failed. thanks all, traded msd for bwd coil and got 14 cash back
Old Sep 24, 2010 | 01:34 PM
Glad to hear all is well. Slow just threw that out there and BAM
Old Sep 24, 2010 | 01:57 PM
slowpoke's Avatar
Car: 1987 Z28
Glad I could help.
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
cstrobel65
Aug 15, 2015 10:19 AM
