Upper Portion of Motor Mount...HELP...
Old Oct 13, 2010 | 09:44 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
so i replaced the rubber inserts on the motor mounts on my 83 camaro and not the upper motor mounts dont bolt on any more...the upper motor mounts came off a different car and they did mount on 2 the old beat up rubber inserts...
so wat do i do?...
do i need the upper motor mounts from an fbody?...
does anyone have sum of this layin around that i can buy off?...will pay asap..
help plz...
Old Oct 13, 2010 | 10:34 PM
Car: 1983 Z-28
Engine: 5.7 L
Re: Upper Portion of Motor Mount...HELP...
any one...help bump...
Old Oct 14, 2010 | 11:11 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
If you just replaced the inserts, did you install them so the metal tabs that run through the insert were sticking out the same direction as the old ones? If you have them backwards those metal tabs will catch on the engine mount before it gets low enough for the bolt holes to line up. If I remember right when the mounts are bolted to the K member, those metal tabs should go straight up and down when looking at it from the front.
Old Oct 14, 2010 | 12:56 PM
Car: 1983 Z-28
Engine: 5.7 L
yes i put the rubber inserts the same way the old ones came off...they r off about 1/8 of an inch off...:/...
Old Oct 14, 2010 | 01:34 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
You have to besure to lower the engine evenly onto both mounts at the same time. If you drop onto one, the other wont line up. They will be tight on the new rubber.
Old Oct 14, 2010 | 05:23 PM
Car: 1983 Z-28
Engine: 5.7 L
yes i did that...one side will go in but the other doesn't...its off about 1/8 or a lil more...:/..i think i need the fbodyupper motor mount...the one i have came off a M.C...
Old Oct 14, 2010 | 07:57 PM
Car: 1983 Z-28
Engine: 5.7 L
anyone have this?...i really need them 2 get my engine back in...
Old Oct 18, 2010 | 04:38 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I swear they're the same. Ive done engine swaps in Montes a few times and in 3rd gens several times. If there was a difference, I never noticed it. Try Hawk's 3rd gen for the part# and compare it, or go to NAPA, or the junk yard. I swear Ive dealt with this and the mounts are just tight.
Old Oct 18, 2010 | 06:31 PM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks yea it might b that they r tight...i just bought ordered sum so ill find out...i hope ur right and prove me wrong so i kno in the future...but thanks...
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
fbirdroller
Sep 2, 2015 10:27 PM
