engine build
Old Oct 14, 2010 | 09:04 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
engine build
Well looks like i need new main bearings. So i was thinking of just building the engine now while its out what would i need to achieve a streetable 350 to 400 whp? Its a 1979 sbc 350 all i currently have is an edlebrock performer intake and a edlebrock 650 carb. So what would a good cam be?? I have a cpl sets of heads but im not sure on casting numbers where are the numbers located at?
Old Oct 14, 2010 | 09:20 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: engine build
The casting numbers are located on the top of the heads where the valve covers would normally cover. My cam choice would be something like the comp 268h. With decent heads and exhaust those numbers are not too hard to reach.
Old Oct 14, 2010 | 09:28 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: engine build
will check the numbers and forgot i also have edlebrock tes headers
Old Oct 15, 2010 | 06:49 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: engine build
Heres one sent these look to be for centerbolt valvecovers and the other heads are not.
here is a picture of one set if you cant read the number its 14102191
Old Oct 15, 2010 | 09:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: engine build
This are swirl-port TBI truck heads, not a great start for a performance build.
Old Oct 15, 2010 | 01:10 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: engine build
heres the 2nd set of heads number is 462824 which set would be better? Or do you suggest getting a set?
Old Oct 15, 2010 | 01:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: engine build
624s are a large chamber, small valve, thin casting smog head from the 70s. If someone gave me a set for free, I'd wonder what I'd done to offend them.
Old Oct 15, 2010 | 01:23 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: engine build
haha ok then ill go with the other ones. Im getting a different shortblock for now but with a roller cam what pushrods would i need with the other heads? And could i swap rockers from these heads? This motor ill be building over the winter so what would be a good set of heads to get? or what else should i do to achieve my 400whp?
Old Oct 15, 2010 | 01:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: engine build
Swirl-ports aren't going to get you 400 HP either, unfortunately. For that much RWHP, you'll probably be looking at something aftermarket.
You might get close to that much flywheel horsepower with a set of good stock heads, or a set of Vortecs.
Old Oct 15, 2010 | 05:19 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: engine build
no im putting the swirlports on another motor to put in the car and run for now. I just need to figure out which pushrods to use. And this motor that needs bearings im gonna build over the winter so ill buy different heads i just need to figure out which ones
Old Oct 15, 2010 | 10:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: engine build
Pushrods will depend on which heads and valvetrain parts you use.
Old Oct 16, 2010 | 07:44 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: engine build
if i just use the springs that are on the swirl ports and the rockers from the 624's would i use the 624 pushrods too?
Old Oct 16, 2010 | 09:17 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: engine build
It would still depend on what lifters, cam and heads you use.
Old Oct 16, 2010 | 02:21 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: engine build
its gonna be a 92 350 tpi motor and those swirl port heads and the rockers from the 624
Old Oct 23, 2010 | 09:32 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: engine build
ended up finding a good deal on a good motor so i can build that along the way. It has 202 heads and a "RV" cam? (not sure what that means) And i have my edle 650 and edle performer intake.
Old Oct 24, 2010 | 12:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: engine build
Sounds like a truck motor with a truck cam, probably with some old 70s smogger heads that have been hogged out to take 2.02" intake valves. Probably makes something like 200 HP
Old Nov 4, 2010 | 05:48 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: engine build
its 3998993 heads
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
