Engine Restorer vs Nano Energizer
Old Oct 23, 2010 | 06:32 PM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
Has anyone ever used engine restorer or nano energizer. I have some pretty deap vertical scratches in a few cylinder walls and would like to use one of these. I was on the nano energizer's website nanoxr.com but there is no way to buy the product from them and it looks like the company is located in germany because all the reviews are written in a different language.
Old Oct 23, 2010 | 06:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine Restorer vs Nano Energizer
I wouldn't count on either to do anything useful.
Old Oct 23, 2010 | 07:21 PM
Guest
Guest
Posts: n/a
Magic in a bottle? No thanks.
Save your money. Buy a new set of spark plugs, or something.
Old Oct 23, 2010 | 07:37 PM
I could be wrong (well, I am WRONG, but, mistaken about this one thing) but I don't think a set of plugs will fix scored cylinder walls. Even if the engine needs plugs ANYWAY, now is not the time. Yet.
There's no such thing as "rebuild in a bottle". Nothing invented yet will fill the missing metal back in.
Save your money. Don't waste any of it on snake oil you'll be needing it for parts. Get the block bored and replace the pistons and rings (otherwise known as a "rebuild"), or find another block, or both.
Old Oct 23, 2010 | 08:02 PM
MikeSammy's Avatar
The block had already been bored .040 over and I do not want to .060 over. Maybe lucas oil will work?
Old Oct 24, 2010 | 01:03 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Time for a new block then. There's nothing you can put in your oil that can magically add back missing metal.
Old Oct 24, 2010 | 05:00 PM
Goany's Avatar
sleeve the cylinders back to 40 over and buy new rings.
Old Oct 24, 2010 | 07:16 PM
Don't do that. That's just STEWPID.
Costs more than another block from yer local buzzard.
IMO there's nothing wrong with a .060" over 350 in most cases. But if you don't like that, your best choice is to simply replace it. It'll cost less than any other possible option.
Old Oct 24, 2010 | 08:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could get 4 used bare blocks for the cost of sleeving all the cylinders.
Old Oct 24, 2010 | 11:30 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Never use restore I have done it twice on okay running engines and both with in a week or so ended up spining bearings (only tried it the second time because I thought the first was a fluke boy was I wrong)
Old Nov 9, 2010 | 06:06 PM
bargranny's Avatar
I have several good bare engine blocks. We used to own a machine shop. (closed due to the death of our son). These blocks have been: magnifluxed, thermal cleaned, bored & honed, cam bearings & brass freeze plugs installed. What I have is: 350-40, 305-30, 429-30, 429-30, 460-30, 351-40, 454-30. If anyone is interested, send me an e-mail with an offer.............take 1 or take all...
Old Nov 9, 2010 | 06:09 PM
bargranny's Avatar
blocks for sale................e-mail bargranny1@aol.com..................
Old Nov 10, 2010 | 10:08 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I had a .060 over block. Developed a crack in a bore after one time around the block.
**** happens. I wouldn't risk it again.
Old Nov 11, 2010 | 03:22 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Just how deep? pictures would really help, it might just need honed depending on how deep they are, but otherwise, Idk if boring 60 over is safe on a 350 or not, but it would certainly be the easiest and cheapest route, unless honing is enough. Otherwise, I agree with these other guys, just find another block....350s are a dime a dozen.
Old Oct 10, 2011 | 04:25 PM
chrisdee's Avatar
I wonder what the wright brothers would say to people who dismiss stuff they have not tested?
Old Oct 10, 2011 | 04:26 PM
chrisdee's Avatar
I wonder what the wright brothers would have to say about dismissing stuff one has not tested?
Old Oct 10, 2011 | 04:28 PM
chrisdee's Avatar
Go ahead and try it. Thats what the wright brothers did and look who is flying all overthe place now, even the to the moon!
Old Oct 10, 2011 | 05:34 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Did you just compare snake oil to one of the most pivotal moments in human history...three times?
So, how long have you worked for them?
Old Oct 10, 2011 | 06:49 PM
What the Wright Bros did involved actually trying something NEW (sort of... not completely "new", but close).
That's quite a bit different from being gullible and going to AutoZone and wasting a chunk of yer hard-earned cash on stuff that's been around for DECADES.
If that sort of thing is your idea of "new" right now, then once you hit your 20s and move out of mom's, you'll see "new" differently.
Old Oct 11, 2011 | 09:08 AM
torque_is_good's Avatar
Holy 1 year BUMP batman!!
if you ever become an aviation mechanic please post on this site for which airline you are employed; I'll be sure to avoid them
Old Oct 12, 2011 | 03:40 PM
RAS's Avatar
RAS
I tried that crap once on an 89' Chevy pickup with 180k miles that smoked. Let's just say it smoked worse and no improvements in compression like they guaranteed, not a big surprise really.
colton_carlson
Mar 8, 2019 12:21 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Street Lethal
Aug 12, 2015 11:33 AM
