HOW TO KNOW WHAT HEAD GASKET TO BUY
Car: CAMARO IROC-Z
Engine: 350 T.P.I
i was looking at copper head gaskets and i was just wondering how do i know what bore and thickness to buy the head thank you very much
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: HOW TO KNOW WHAT HEAD GASKET TO BUY
Need more info... what size engine are you putting head gaskets on? Iron or aluminum heads? Is it a fresh rebuild (never run) or an engine with some miles on it?
Car: CAMARO IROC-Z
Engine: 350 T.P.I
well its a 1989 350 iron heads it has miles on it im just rebuilding heads and i dont want to get cheap ones from auto zone but on summit its asking for bore and thickness
Just use a standard Fel-Pro rebuilder head gasket set. The ones with the blue rubber coating on them, called a 'perma-torque' gasket or something like that. I think they are around .039 thick. These gaskets work really well, and don't need to be retorqued later. You don't need anything fancy for what you are doing.
Car: CAMARO IROC-Z
Engine: 350 T.P.I
SWEET THANK YOU VERY MUCH IM TAKING OUT MY ENGINE TO REPLACE SEALS AND ALL GASKETS AND FREEZE PLUGS AND WHILE I HAVE AN ENGINE OUT IM THINKING OF DOING A SIMPLE REBUILD BUT LIKE MAYBE HAVING A BIT OF AN UPGRADED CAMSHAFT BUT DONT WANT ANYTHING TO VER THE TOP WHERE I AM GOING TO NEED TO UPGRADE INJECTORS AND COMPUTER OR TRANS. AND WONDERING WHAT LIFT AND DURATION WOULD BE A LITTLE BETTER THAN STOCK BUT NOT TO WAY HIGH PERFORMANCE AND ALSO PISTON TYPE
A set of flat-top pistons and a stock cam from an LT1 would be a good way to go.
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Hey Adam, I'm pretty much doing the same thing with my L98. The original gaskets measure .028 thick. Won't going to a .039 gasket lower the compression ratio? Just asking, Thanks.
You're right, it will lower the CR, but the drop is very small. It won't make any noticeable difference.
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Why don't I join in? Adam, I have a 350 that's bored .40 over. Iron heads nothing fancy done to them. I bought the standard Fel-Pro head gaskets and used those. Was this a bad idea since I'm bored? Or am I okay?
ambainb
Apr 25, 2016 09:21 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
