"Burnt Valve" ??
Old Nov 7, 2010 | 04:40 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
"Burnt Valve" ??
Oh mighty gurus--
Enlightenment please??---
How do you know if you have a "burnt valve"??
Hear it tossed around, mostly by drag racers, but confused by what it means & the symptoms!!
Also, what is the likelyhood of it occuring to a daily driver??
( edit )
Thank You for any education you can pass!!
Old Nov 7, 2010 | 07:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: "Burnt Valve" ??
Do a compression test, or better yet, a leakdown test, and if you have low compression and you narrow the cause down to a leaky valve, then you have a "burnt" valve.
The odds of it happening in an unabused daily driver are relatively low.
Old Nov 7, 2010 | 08:21 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Years ago (mid 70's) there was a vacuum gauge that would indicate if there was a burnt valve. I am not certain if that applies to more modern engines. Never run into one.
Old Nov 7, 2010 | 09:08 PM
Car: '87 Camaro
Thanks Apeiron!! Easy 'nuff to remember & apply!!
jwande--Never seen that before!! TDC the cylinder, Pull vacuum from the plug hole??
Old Nov 7, 2010 | 09:18 PM
jwande's Avatar
Engine: 305 TBI
No you just hooked the gauge up, and the scale gave an indication the valve was burnt.
Old Nov 7, 2010 | 09:29 PM
Car: '87 Camaro
Interesting!!
Thanks for the replies!!
Old Nov 7, 2010 | 10:46 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
t-top,
A vacuum gauge connected to an intake manifold vacuum port will indicate some of the problems that relate to intake valves.
A crude test that can (or not lol) reveal a burnt exhaust valve is try to hold a stiff piece of paper against your tailpipe & watch for the engine to suck it back toward the pipe.
Both tests are done w/the engine running.
Leak down tests are much more conclusive but require special tools.
Old Nov 8, 2010 | 12:14 PM
jwande's Avatar
Engine: 305 TBI
Originally Posted by xch3no2
t-top,
I have heard of the paper test before. We never used the vacuum gauge for anything other than trying to determine if we had a vacuum leak. As mentioned before, I have never run into one in my 24 years of working on all types of engines - tractors, implements, cars, trucks, motorcycles, small engines, and boats.
Old Nov 8, 2010 | 12:24 PM
Moe87's Avatar
Thats a good idea, I'll try that for my car later as well.
I do not mean to threadjack but could a leaking manifold cause a burnt valve?
Old Nov 8, 2010 | 12:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A vacuum gauge might work on a 4 cylinder tractor idling at 400 RPM, otherwise it's pretty hard to see a problem in an individual cylinder, especially with a large plenum.
Old Nov 8, 2010 | 03:15 PM
jwande's Avatar
Engine: 305 TBI
I agree. We didn't use it often, and you are correct, only once or twice on a car/truck engine. I forget the spec, but you would look for the drop whenever the burnt valve operated. If you had a hot cam, you'd never find it with the vac gauge. Just a different method that I learned on years ago.
Old Nov 8, 2010 | 03:40 PM
xch3no2's Avatar
Transmission: TH400
This appears to be a serious lack of skills/experience.
The dip & flutter of a vacuum gauge attached to the intake of an engine with a bad intake valve is distinct & obvious.
Elvis has left
Old Nov 8, 2010 | 03:47 PM
Guest
Guest
Posts: n/a
That is what I have heard as a cause, a leaking exhaust manifold. I've seen burnt valves, but not on SBC motors. Usually the Dodge V6's, and some older foreign (Japanese) stuff.
Old Nov 8, 2010 | 03:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Distinct and obvious when everything is agreeable, like the grind of the cam, engine speed, plenum volume, responsiveness of the gauge, length of the tubing, exactly how badly the valve leaks...
Old Nov 8, 2010 | 05:45 PM
Car: '87 Camaro
IMO--
Not a jack!! That Q does fit, & not a bad 1 at that!!
(edit)
Along the lines of Moe87--
How do you know when? What symptom(s) are looked at?
Way down on power all of a sudden? Knocking or ticking? {I mean not like a valve tick or header // manifold gasket leak tick} Smoke erraticly, such as when said cylinder(s) are on the exhaust stroke?
Last edited by t-top havoc; Nov 8, 2010 at 07:42 PM. Reason: No need to make a new post#??
Old Nov 8, 2010 | 11:13 PM
Guest
Guest
Posts: n/a
Loss of power. Its usually a gradual thing, I dont think you'd notice any noise out of the ordinary from the valve itself. Best way to check is compression test, IMO.
Old Nov 9, 2010 | 07:36 PM
Car: '87 Camaro
Thanks to all for the input and patience!!...
I understand now what it means, & what to do!
Glowsock
Jul 24, 2025 03:15 PM
Elephantismo
Feb 13, 2019 12:51 AM
Bigold4x4
Sep 28, 2015 05:21 PM
gta892000
Sep 16, 2015 12:37 AM
someone972
Aug 30, 2015 12:52 AM
