Heater Core help...
Old Nov 24, 2010 | 05:50 PM
BLo602's Avatar
Car: 1989 Chevy Camaro RS
Engine: 350 TBI
Heater Core help...
Just recently got my 89 camaro rs, now that its getting a little cold outside Im ready to use my heat.... 1 problem... Heater core has been disconnected. So i guess my question is where do i route the heater hoses to starting from the heater core???
Old Nov 24, 2010 | 05:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Heater Core help...
If they're disconnected, it's almost certainly because the heater core is leaking. If you connect them without replacing it, you'll just dump coolant into your interior.
Old Nov 24, 2010 | 05:59 PM
mightymaro94's Avatar
sounds like a new heater core install in your near future... theres no GOOD reason i can think of to disconnect the H.C.
Old Nov 24, 2010 | 06:04 PM
BLo602's Avatar
Engine: 350 TBI
Yeah i kinda figured that... so i guess i shouldve asked after i install a new heatercore, where do i route the heater hoses?? Thanks for the quick responses i appreciate it
Old Nov 24, 2010 | 06:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's no heater hoses under the hood right now? Normallly they're just looped together with an adapter to bypass the core when it leaks.
Old Nov 24, 2010 | 06:16 PM
BLo602's Avatar
Engine: 350 TBI
The right fitting on the heater core has no hose on it, but the left fitting has an upside down T shaped hose on it.... one end of the ''T" hose is connected to the heater core of course and the other 2 ends aren't connected to anything. Not even each other.
Old Nov 26, 2010 | 09:17 AM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
These diagrams are for an '88 but yours should be similar (if not the same);
Old Nov 28, 2010 | 10:46 AM
BLo602's Avatar
Engine: 350 TBI
Thanks, I really appreciate it
ndndndnd
Sep 28, 2015 08:00 AM
Formula8r89
Sep 22, 2015 04:24 PM
