350 TPI Hard to Start - please help
Old Nov 27, 2010 | 01:19 PM
bselltiz's Avatar
Hi all,
My 89 350 is hard to start and I don't know where to go from here.
I have to prime the fuel pump 2 to 3 times to get it to start when it is cold.
Only once when it is warm.
Already replaced the following:
Cap/Rotor
Plugs/Wires
Injectors
Fuel Filter
What do I do next?
Old Jan 5, 2011 | 07:48 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Re: 350 TPI Hard to Start - please help
Anyone? I have a similar issue.
Old Jan 5, 2011 | 07:53 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
bad cold start switch or cold start injector typically
Old Jan 5, 2011 | 08:03 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
NOT IN 1989
Old Jan 5, 2011 | 08:08 PM
bselltiz's Avatar
Mine tends to idle high for a bit too, almost to 2k rpm. Doesn't go down until you drive it for a short time. Not sure if that would be related.
didnt see that, only had csi up to 88, 89 the ecm does injector enrichen instead
Old Jan 5, 2011 | 08:12 PM
regal301's Avatar
Car: 1988 iroc-z
THE MAF TPI SYSTEM IS JUNK. ALONG WITH THE STOCK INJECTORS.
I REPLACED MY INJECTORS AND IT GOT BETTER.
I PURCHASED A STAND ALONE SPEED DENSITY HARNESS,ECM AND PROM.
CURED EVERYTHING............HOT START ISSUE,LONG CRANK,IDLE SURGE,COLD STUMBLE.
EVERY PROBLEM ANYONE HAS EVER COMPLAINED ABOUT I HAD,I TRIED EVERYTHING.
ONLY THING THAT GOT IT RIGHT WAS THE INJECTORS AND CHANGING IT OVER TO SPEED DENSITY.
SORRY ABOUT THE CAPS LOCK
Old Jan 5, 2011 | 08:15 PM
regal301's Avatar
Car: 1988 iroc-z
Old Jan 6, 2011 | 01:01 PM
Car: 87 IROC
Engine: 5.7 TPI
Yeah, I've had a lot of problems in the past with the MAF, but managed to solve them all with time. It actually is a rather efficient system (when it is working). I do think the cold start injector is likely my problem. I recently replaced the injectors with modified Bosch 3's so the injectors should be alright, I'll check the CSI later on. Thanks for the feedback.
Old Jan 6, 2011 | 01:27 PM
regal301's Avatar
Car: 1988 iroc-z
you have the cold start injector , the OP does not.
you can eliminate the cold start on your car with a 89 prom.
theshackle
Mar 5, 2017 06:37 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
