Motor mounts stuck to the crossmember
Car: 1982 Trans Am, 1986 Gmc sierra
Im getting ready to swap my new motor in, and want to replace the old motormounts, seems simple enough. step 1 : Remove the three bolts holding them to the crossmember. I tried but all 6 bolts just want to spin and not get any looser or tighter. WTF
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Re: Motor mounts stuck to the crossmember
Do a search on the site for changing motor mounts. It is easiest to clamshell the mount and change the rubber.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The holes aren't threaded, there are nuts inside the frame.
Engine: 305 TBI
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what does that even mean?????
to do anything to the motor mounts you still have to take them off.
OP, as Aperion stated, there are nuts inside the k-member. You can access them through the a-arm pockets, but its a PITA. Its easy to do with the a-arms removed however. I have done it without taking them off, but its really tricky.
Engine: 305 TBI
Do a thread search on 3rd Gen for motor mount replacement. You separate the metal frame like a clamshell would open and replace the rubber inside. This means you leave the nuts and bolts in the frame and the base of the mount.
Engine: 305 TBI
Sorry - correction. You leave two of the three bolts in the frame. One is removed when clamshelled. BUT - you only have to mess with one of them and it is up front and easier to get to.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
