Good Set of headers?
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
HI i am looking for a good set of shorty headers for my 90 Rs camaro that i put a 350 in. i want some headers that will clear with out me having to cut and hack up my car.
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Good Set of headers?
I have the Hooker 2460's on my car now with the matching Y pipe. They were easy to install and I didn't have any problems putting them on my car. Mine doesn't have A/C though, which helped out some with the install.
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
I am saving up for Dyno Dons headers. Everyone only has good things to say about them and they clear everything. (it's tight though)
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Just giving you more info for your decision.
Car: 1987 Trans Am
Engine: Chevy 350 .040 over
I have edlebrocks (emissions passable) complete with Y-Pipe. They fit great but I DO NOT like them. They did not seem to free up much power. Just trying to add to the cross off list.
Also, take a close look at flanges on each product you consider. Different flanges can make it difficult to swap other exhaust components down the road. (i.e. the edelbrock ones I have use a two bolt flange while many use a three bolt)
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
PM me for details....with or without smog tubes
Car: 1990 RS Camaro
thanks guys. i looked and the 1 5/8 size pipe is what is recommended for the most power. and i am on a low budget so i will most likely go with the cheapest kind.
Navy8125
Aug 22, 2015 07:13 PM
