91 5 Speed TPI Shuts off when slowing down...
Old Jan 17, 2011 | 06:36 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Any help would be greatly appreciated...
So engine runs strong and powerful, shifting all the gears... up in 5th... I have to slow down for a light that is coming up, so I go from 5th to neutral and the engine shuts off...
Car starts right up at the light... Sometimes at the light, same thing... with the AC on, even harder time staying running...
Optoma Yellow top battery, new power and ground, hooker 2055 headers with air tubes, new o2 sensor, 3" exhaust, new msd cap rotor and wires, new spark plugs, etc...
I did put in a Brian Harris Chip this weekend with a lower thermostat, but it was doing this problem before and still doing it... If anything, it seems to be idling better than before the chip...
Any ideas or suggestions?
Rafael
Old Jan 17, 2011 | 07:44 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: 91 5 Speed TPI Shuts off when slowing down...
Was the car 5 spd originally?
Also, does your speedometer work?
Old Jan 17, 2011 | 08:03 AM
luvofjah's Avatar
Yes, 5 speed originally.
Yes the speedometer works...
I'm in the process of converting over to a KR replica, and I need the speedo for the ECM...
Again, but it's been doing it for a while, before I began changing stuff....
Old Jan 17, 2011 | 08:12 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I'm not sure then - My car has the same issue but it's caused by the fact that my VSS isn't hooked up.
BTW: If you're doing a KR conversion and want to sell your front bumper, I'm interested - I need one and my car is black, too!
Old Jan 17, 2011 | 08:16 AM
luvofjah's Avatar
Yes, the speedo has worked throughout... I have a data logger (not moates), but my laptop battery died and I don't have an extension cord long enough for a long run
I sold the bumper a few years ago, sorry...
Rafael
Old Jan 18, 2011 | 01:08 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Clean your throttle body. The IAC manages about 40% of idle air. The other 60% passes by the throttle blades. If they become coked, and they do over time, the IAC is then expected to handle 100% of idle air which is doesn't do very well. Sudden release of the throttle, with coked thottle bores, will cause engine speed to dip below idle and often cause stalling. To clean throttle, use TB cleaner and a course rag and 3/4" bore brush. Spray cleaner in throttle to saturate deposits. Use brush to scrub surface while holding throttle open. Use rage to wipe out loosened deposits. Repeat process until thottles are clean.
If probelm persists after throttle cleaning, check EGR for sticking or slow closing(broken spring? sticky EGR solenoid?). Check IAC for deposits and clean as necessary.
Old Jan 18, 2011 | 01:11 PM
luvofjah's Avatar
Will do, thanks for your knowledge... getting some body work done and tons of other stuff finished, gotta get this thing moving
Rafael
Old Jan 29, 2011 | 07:20 PM
64elko's Avatar
Car: 64 elcamino
say i have the same problem ,,,throttle body is clean an it still doing it....
Old Jan 29, 2011 | 09:03 PM
luvofjah's Avatar
Cleaned throttle body, running better, but still doing it too... will check egr next...
Rafael
Orr89RocZ
Apr 25, 2016 08:28 AM
IBrockZ
Aug 20, 2015 12:20 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
