shift light
Old Jan 25, 2011 | 08:15 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
shift light
hey guys just wondering if any of you also have the shift up light that comes on in your AUTOMATIC. any answers comments explanations would be appreciated. (and no my car wasnt converted i have the original window sticker)
Old Jan 25, 2011 | 08:28 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: shift light
You can buy a tach that sits on your dash that also has a shiftlight.
http://www.google.com/products/catal...d=0CGoQ8wIwAg#
Or something at your local autozone, I know there is one in my store.
Old Jan 25, 2011 | 09:32 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: shift light
There is the space and the printed colored part has the arrow with "shift" in the idiot light area of my 89 but no bulb. I wonder if I put a bulb in, will it light???
But whats the use!
If I can find mt spare bulbs and sockets when I pull my cluster so I can lube the speedo cable I'll give it a shot!
Old Jan 25, 2011 | 09:44 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: shift light
yeah it should im not sure why the factory would let it roll off the assembly line like that though? it says on when in fouth gear, i used to have a 5 speed s10 that had that light. so im guessing the computer or sensor thinks i have another gear left.
Old Jan 25, 2011 | 09:49 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: shift light
you obviously didnt catch my drift. my cars an auto and has a shift like just like a early 90's 5 speed chevy would have. ive never seen a shift light in an auto from the factory, just trying to see if that was a camaro thing or what
Old Jan 25, 2011 | 09:50 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: shift light
Is this like that "Power injection" on the dash of the grand nationals? (apparently they were going to do meth injection) but actually released the cars without it; yet it still has a spot on the dash if you shine a flashlight on it.
Old Jan 25, 2011 | 10:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: shift light
There's nothing special about it. The same panel was used for automatics and manuals, the automatics just didn't have the bulb installed behind it. In earlier ECMs, the output driver for the shift light in manuals is used for the TCC signal in automatics, so you'd get a light that does various interesting things when the TCC locks and unlocks. In the ECM for a 91 I think there are distinct drivers for the two functions though.
Old Jan 25, 2011 | 10:15 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: shift light
Im looking at a wire diagram and I believe somewhere along the line at one time someone put a bulb in there and that is why it lights.
The cavity on your ECM for the TCC is the same cavity used for the upshift light on a manual. The wire coming off the the same curuit also go to the light. The diagram just says "not used" for the auomatics and the wire goes to the same cavity on both.
So I bet if I installed a bulb it would also come one when the TCC engages.
When you step on the gas in 4th does it go out?
Old Jan 26, 2011 | 08:56 AM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: shift light
Ahh I thought you were talking about an aftermarket shift light, but everyone else in this post pretty much explained what I would have said.
Old Jan 26, 2011 | 05:41 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: shift light
yeah i know they are all the same panel but i do actually have the light that comes on between gears depending on rpm and stays on after i shift into 4th unless i accelerate. but thank you Apeiron you pretty much answered it, just something i was curious about.
LittleFranks
Sep 17, 2015 12:22 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
