low rpm stalling
Old Feb 6, 2011 | 03:53 AM
Gibson's Avatar
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
low rpm stalling
So I cleaned my EGR and replaced my IAC in an effort to fix my stalling problem when stop. It agrivated it and now below 1500rpm, she loves to stall out. Should I remove my EGR and see if that fixes it? My old IAC is pooched, the spring is bad. I cleaned my t-body as well. What do gods of third gen?
Old Feb 6, 2011 | 07:43 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: low rpm stalling
This is going to sound strange but it could be your torque converter. If you have a lockup TC on your car it should unlock when you slow down. If it doesn't, your car will stall when you come to a stop. Yeah, I know it sounds weird but I experienced it first hand. It took an 60+ year old third gen fan to figure it out. Replaced the TC and the problem went away. To clarify, this only occurs if you are slowing down from cruising speed. It really depends on your TC. If your car stalls when you start it or when leaving the driveway, this isn't the problem.
Steve
Old Feb 6, 2011 | 01:28 PM
Gibson's Avatar
Engine: LB9
its not the TC as it stalls in any gear, park, nuetral, drive, and gear at all. maybe my IAC passage is blocked up? or my EGR **** hte bed? im thinkin its a fuel or air problem cause to start it i need the t-body all the way open.
Old Feb 6, 2011 | 03:34 PM
Gibson's Avatar
Engine: LB9
after reading like 15 threads on this problem, i think i have it narrowed down to CTS and fuel filter. considering i have to give it gas to keep it running and have to pump the gas while starting to get it to start, im leanin twards a dieing CTS
Old Feb 7, 2011 | 09:46 PM
Gibson's Avatar
Engine: LB9
i fixed the problem, idk how, but i did. then i wrecked my car. i need a rear axle for it ASAP!
Old Feb 12, 2011 | 03:11 PM
adilson delima's Avatar
Transmission: AUTO
what 's a CTS? i am tring to figure it out wha's going on with my 90 RS.
when i'm driving it's fine , but when i step on the brake at a light or a stop sign, the rpm goes up and down ,and if i don't give some gas, it would just stalls, is that what was hapening to yours?
Old Feb 12, 2011 | 03:55 PM
Gibson's Avatar
Engine: LB9
yeah, i cleaned all my senesors and remeved my egr
Old Feb 12, 2011 | 04:49 PM
Transmission: AUTO
i'm sorry, i have no knowledge of EGR stands for, can u explain, maybe i'll do the same on my!
Old Feb 12, 2011 | 05:25 PM
Gibson's Avatar
Engine: LB9
Exhaust gas recuculation
Old Feb 12, 2011 | 06:39 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
stalling when you're stopped could from a bad VSS (vehicle speed sensor) this tells the car when it's moving and can mess up idle speed.
Old Mar 5, 2011 | 04:53 PM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
Steve
i have the exact same problem right now, although my car seems to have a bit of a low idle, only when im slowing down to stop or have to stop quickly my car will stall out and die, i can throw it in nuetral or park and it will start right back up no problem, so i wonder if the torque convertor isnt unlocking? its the stock coverter. Ive also been told it can be the iac or possibly fuel filter?
jklein337
Sep 19, 2018 06:23 PM
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
Jake_92RS
Aug 17, 2015 09:42 AM
TreDeClaw
Aug 14, 2015 06:58 PM
