am I redlining
Car: 84 z28
Engine: 5.7 tpi
Transmission: t5
Axle/Gears: not sure
am I redlining
okay so im not sure year hp or anything of my 350 has a t5 tranny and I noticed the rpms go by the 100x okay it idles at 150(thats normal right) and I believe that the numbers turn red at around 5 at stop at 7 but in my personall opinion it doesnt sound like its time to **** until 7 if Im really getting on it a lil help here
ps can some show me where to find the engine id at with picture preferable
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
Re: am I redlining
yeah, mine idles at 1400-1500, seems to be as low as mine can go without dying. as far as the rpm's.. same as well. starts at 5, ends at 7.
Re: am I redlining
Re: am I redlining
I'm guessing, this is what the factory "tach" says?
That pointer-wavy thing in your dash isn't really a "tach"; it just looks like one. Consider it a tach-shaped "sport trim" object. They are notoriously inaccurate from the factory, since all they're supposed to do, is go up and down in rough accordance with engine RPM to convery an "image" to the driver of "sporty" appearance, but aren't designed to be "test equipment" grade.
Sounds like yours has failed in the mode they ordinarily do, which is, to read WAY high. Sounds like yours is reading at least double the actual engine RPM. Fairly typical. I have a pile of em; I have one that was only about 5% high last time I checked it against a CALIBRATED frequencey counter, and I think I have one (haven't thrown it away yet) that reads 3 times actual.
Normal idle, as per the sticker on your radiator core support, is something in the range of 650 RPM. Since your motor isn't factory, "normal" could be almost anything, but isn't likely to be 1500 RPM.
You may also have the further complication of a 6-cyl tach hooked to a V8 engine, which would also cause it to read high by a factor of 8/6 (1.33333 times what it should), even if it was dead-on accurate.
Car: 84 z28
Engine: 5.7 tpi
Transmission: t5
Re: am I redlining
so I need to go buy an aftermarket rpm gauge, and as for my speedometer I assume isn't plugged up because it doesn't work, its it a pain in the *** to plug it in and will it work correctly if I get it plugged in
Re: am I redlining
Couldn't say about "need"; lots of cars seem to get by just fine without a tach. But yes, you either need to replace it, or fix the existing one. There's a write-up somewhere on this site about that.
Yes plugging the speedo cable in would increase its chances of working. I have no clue whether anything else is wrong with yours or not. Probably not but who knows.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: am I redlining
A true 1500 rpm idle at operating temp would seem really high to you, so your tach is off as mentioned. A 'normal' idle would be 600 - 1000 depending on the car. Older basic emission sniffer tests wouldn't 'sniff' if the idle was above 1100, since at that rpm most emissions would be less anyway - they would fail the car until the idle was lower.
Re: am I redlining
Starts at the trans, ends at the dash; might go through the cruise along the way, depending on what kind of car you have and what year and whether it even has cruise
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: am I redlining
You dont say what year the car is. At some point(89 IIRC), the speedo drive changed from cable to electronic with a VSS installed in the trans. Assuming it's an early version, most likely, since the engine has been replaced, the cable is disconnected from the transmission.
Car: 84 z28
Engine: 5.7 tpi
Transmission: t5
Re: am I redlining
yes it is a 84 is it so simple a caveman could do it Im really new to cars
Re: am I redlining
You can handle it.
vadrad
May 26, 2001 07:01 PM
