Will this have a lumpy sound?
Old Feb 14, 2011 | 04:12 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
id like to start off saying i know nothing about cams lol
i picked up today a hydr. roller lunati cam and roller lifters for $80 the cam has .480 lift(only thing i know about it) tried to search the p/n 60113 but it says the lift to that cam is like .520 or something so im assuming its a different box he put the cam in...i plan on making my engine into a roller next winter with a 400 crank..my question is will this cam make a lumpy sound or no? i love that sound lol i dont no if thats enough info for my question to be answered or not...My engine specs right now are
350 2bolt main
.20 over
dish piston
mild cam
steel crank
edlebrock performer intake
10.7:1 compression
416 ported/polished heads
hedman shorty headers
hei ignition with advance curve
flowmaster 3"exhaust
accel wires
thanks
-Josh
Old Feb 14, 2011 | 04:31 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Will this have a lumpy sound?
yes
Old Feb 14, 2011 | 04:35 PM
Engine: 355
Good cam, give you fifty bucks for it. http://www.lunatipower.com/CamSpecCa...rtNumber=60113
Old Feb 14, 2011 | 04:54 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Sarcasm? I'm assuming? Should I just leave the cam I have in there now or give it a shot?
Old Feb 14, 2011 | 05:16 PM
Engine: 355
I said it was a good cam or I would have not tried to buy it. It is going to make good power in the upper RPM and should kick around a good bit. I would run it in a heartbeat.
Old Feb 14, 2011 | 05:20 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
sorry i assumed it was sarcasm...i tend to see alot of it on this site...but thank you for the info i cant wait to run it would i need to change the stall converter? pistons or anything else?
Old Feb 14, 2011 | 05:23 PM
Engine: 355
Check springs, push rod length,and piston to valve clearance. Like my new Avatar?
Old Feb 14, 2011 | 05:42 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Lol very much so it's pretty funny and thank you for all your advice
Old Feb 14, 2011 | 06:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Where did you get the cam number from ?
Off the box or off the cam?
If it is indeed a #60113 ;
then at 243 / 251 .560 lift that is a serious cam with very rough idle
May need more compression to get it to work and a hi stall convertor
Old Feb 14, 2011 | 06:58 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
got it off the box the only number i could find on the cam that looked like a part number was 4714..but i couldnt find it anywhere
Old Feb 14, 2011 | 07:48 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Great avatar!!
Old Feb 14, 2011 | 07:57 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
got it off the box
Think about it.
Guy buys and installs new cam , puts old take out cam in the new box to sell it
How do you know cam is Lunati?
Old Feb 14, 2011 | 08:19 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
thats true where can i find the p/n on the cam?
Old Feb 14, 2011 | 08:29 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
these are all the numbers off the cam hopefully someone can give me a hand
4714 EP ,27 F2,CWC, C1 D1,ERTEL 4714
Old Feb 14, 2011 | 08:49 PM
Ertel is (was) a company that makes (made) the cheeeeeeeepest of the cheeeeeeeep "rebuilder" stuff. Pistons mostly. They "sold" about everything, cheeeeeeepest of the cheeeeeep, to yerbasic cheeeeeeeeeep low-bid "rebuilders" for bottom-dollar "rebuilt" motors. You know, the kind that have a 30-day warranty, and if you get a GOOD one, last about 60 days.
Sounds like you have one of their cams.
See this post for someone else who had one. https://www.thirdgen.org/forums/tech...737-ertel.html (It's always FUN when Google points you back to something you wrote half a decade ago!!) Might be the same as the one you have, might not. Might be a 929 copy. That's what most of em were.
I also told that guy how to measure it, what it would measure, and .... surprise!!! .... guess what it measured. Go measure yours using the same technique, and you'll know right away pretty close to what it is.
If you paid $80 for it, that's about $100 more than I would have paid for it, and about $30 more than you can buy it brand new from Summit. This is what the other guy had. http://www.summitracing.com/parts/SUM-1102/ This is a copy of the 929. http://www.summitracing.com/parts/SLP-CS-274/
Sounds like you just learned a growing-up lesson the HARD way. The lesson being, ask what it is BEFORE you buy it, not AFTER.
Old Feb 14, 2011 | 08:53 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
well i also got comp cam roller lifter in the $80 so im gonna look alittle more into it if not goin back to the guys house and gettin my money back.. lol
Old Feb 14, 2011 | 09:19 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
i put 4714 ep in google and it comes up edlebrock...put i was also looking around and it says its crane cams...soooooo now i really dont know i also looked up ertel and it says they only made hydro roller cams for propane and turbo engines and cop cars with 480 lift...soooo i really dont no know the ertel looks like its a machine stamp..but hell if i know now
Old Feb 14, 2011 | 11:42 PM
Don't worry about stamped numbers or the PO's story about ".480 lift" or who Ertel is/was, if you can't find it. Ertel may well be out of business and not have a web site.
Measure it. It is what it is. Measuring it will tell you what it is. If I were the betting kind, I'd bet it will measure to be one of the 2 cams I posted above.
Old Feb 14, 2011 | 11:53 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
that cam should be very lopey!
Old Feb 14, 2011 | 11:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Did you read the whole thread?
AS sofakingdom notes the cam he most likely has is 204 / 214 or 194 / 203 ; not exactly earth shattering
The Lunati # 60113 he wishes he has is lumpy
Old Feb 15, 2011 | 07:20 AM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
ive now discovered its a Clevite-Mahle cam..which i have never heard of still has a 480 lift which i dont know is big or not i cant find any info on there cams i just get a discription of what the cams are like off the website has anyone else heard of these cams?
Old Feb 15, 2011 | 11:36 AM
And you "know" this .... how??
MEASURE IT.
Mahle bought the Clevite name a couple of years ago. Before that, it was the TRW trademark for their bearings. Other engine parts supplied under that nake were basically more "rebuilder" stuff. However, neither TRW, Clevite, Mahle, or ANY OTHER engine parts mfr, marked their products "Ertel". Only ONE company did that... ERTEL. That's whose product you have. No point in denying it.
None of which matters very much. MEASURE IT. That will tell you FOR SURE what it is.
Old Feb 15, 2011 | 12:17 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
My engine has a similar cam in it...
Old Feb 15, 2011 | 12:25 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Email Lunati your specs, and what you want.. They'll suggest a nice cam for you, and one that will fit the clearances on your heads.
Old Feb 15, 2011 | 12:41 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
MEASURE IT.
i went to the machine shop and he measured it and it is a 480 lift and is possible a melling cam and ertel shipped it out iunno anyway the lifters are only good with an 88 and up block along with the cam so ill be taking it back anyway lol and picking one up from summit and never buying a used cam again -.-
Old Feb 15, 2011 | 12:46 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
thanks for the info ill do that right now
Old Feb 15, 2011 | 03:19 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Missed that part lol. Only read the first few posts.
Old Feb 15, 2011 | 06:11 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
they told me to get lunati 00010lk so it has been ordered lol thanks for everyones help!
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
