Parts Help
Old Feb 23, 2011 | 09:07 AM
sch151's Avatar
Parts Help
Any one know where I can find the bracket that holds the Cruise Control Cable and the Throttle Cable to the Plenum. Not the one closest to the TB but the one between the middle runners on the drivers side of the Plenum. Looks like a glorified spark plug wire holder but it has been discontinued from GM. If it is unavailable, has anyone figured out a different mount for the cables or is it really necessary...this is my first TPI motor.
Thank you...
Old Feb 23, 2011 | 09:20 AM
Steel Armadillo's Avatar
Car: '85 Sport Coupe/Z28
Engine: N/A 350
Transmission: TH350
Axle/Gears: Factory 10-bolt w/3.08
Re: Parts Help
If you can find a picture, I very well may have it. I just cant recall what It looks like.
Old Feb 23, 2011 | 09:32 AM
sch151's Avatar
Re: Parts Help
Sorry...But how do I attach a picture?
Old Feb 23, 2011 | 09:44 AM
sch151's Avatar
Re: Parts Help
I think I figured it out...it is #22 in the picture. Please let me know and Thank you!!
File Type: pdf
Old Feb 23, 2011 | 11:37 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Parts Help
Have you tried Hawks or ThirdGen Ranch - I'm sure one of them has one lying around.
Old Feb 23, 2011 | 01:43 PM
sch151's Avatar
Re: Parts Help
Contacted Third Gen Ranch...they only sell complete units. At least that is what they told me. What is Hawks?
Old Feb 23, 2011 | 01:58 PM
Car: 1992 RS
Engine: Carbed 350
Re: Parts Help
http://www.hawksthirdgenparts.com/
Old Feb 24, 2011 | 09:17 AM
Engine: N/A 350
Transmission: TH350
Re: Parts Help
Sorry, I don't have it.
Hawks would probably be your best bet for an original.
If it really is a glorified spark wire holder, why not go to a Pepboys or something similar and get one, they sell them with different numbers of holders. Then depending on the size of the cables, use rubber grommets so they fit snug. Just an idea.
Old Feb 24, 2011 | 09:33 PM
sch151's Avatar
Re: Parts Help
Thanks for checking...I spoke with Hawks. It is actually two pieces...a bolt that attaches the cable holder to the plenum and the plastic cable holder. I have the bolt and they won't just sell me the cable holder. I'll try something like you mentioned unless someone else chimes in here.
I also need a stock water neck inlet if anyone has one of those...
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
