350tpi won't start
Old Mar 12, 2011 | 09:51 PM
nutzar4's Avatar
Car: 1988 Pontiac Trans-Am GTA
Engine: 383 stroker tpi
Transmission: 700r4 Transgo full shift kit
Axle/Gears: 2.73* Posi
350tpi won't start
I have a 1988 trans am gta with a 350tpi engine. It has spark and I belove of is getting gas cuz I smell it and must be getting air cuz it misfires. It goes pop pop pop pop continuously but doesn't start I checked the timing like the book said line up balancer at the 0 degree mark On timing cover and set the distributer to number one firing Position, can anyone tell me why It won't start thank you
Old Mar 12, 2011 | 10:01 PM
64elko's Avatar
Car: 64 elcamino
Re: 350tpi won't start
hi
yes i am having the same problem.... got 45 pounds at fuel rail, strong blue spark,got air,got power to injectors, fuel to injectors,,it sounds like to wants to start ,but nothing..
Old Mar 13, 2011 | 06:34 PM
bobbyk3lly's Avatar
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
from cranking on them so much id try replacing the plugs, my car was doing exactly what both of yours were doing and i changed the plugs and it fired right up
Old Mar 13, 2011 | 08:47 PM
64elko's Avatar
Car: 64 elcamino
hello
thanks for the responce,,, my plugs are brand new
Old Mar 13, 2011 | 08:56 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
You could be 180* off on timing if you did this and weren't on the compression stroke.
Old Mar 14, 2011 | 11:01 AM
64elko's Avatar
Car: 64 elcamino
hello
thanks for responce ,,,timing is on the money....
Old Mar 14, 2011 | 01:49 PM
JustCruzin's Avatar
To both of you. Something is not on the money here. I would double check everything again to make sure. Timing, wires, fuel pressure, filter. Go over it again one more time. Sounds like timing to me G-Reg might have it right could be something simple, Good luck
Old Mar 14, 2011 | 02:09 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
+1 crank pop pop pop means off timing. did you put your finger over #1 hole and wait for pressure to build up?
Old Mar 14, 2011 | 06:49 PM
64elko's Avatar
Car: 64 elcamino
hello
thank you for the responce....timing on the money,,,, i found orange spark today while cranking it over,,,,, not bright blue....
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
