VATS Module
Old Mar 13, 2011 | 08:36 AM
Jcase350's Avatar
Car: 90 Camaro Iroc-z
VATS Module
Another question for you guys. I know my VATS module is bad in my Camaro. I have ohm'd it out and it has the correct resistance all the way down to the module. My question is..will the VATS module that Autozone sells work as a fix for a bad module. Would I have to get a different key? Thanks guys
Old Mar 13, 2011 | 09:19 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: VATS Module
I would imagine that unless it's asking for a specific resistance no, unless it's like the i believe HAWKs version, and first time u turn the key it burns the resistance into the box, but again, I thought that was something special they sold. What's your resistance? I have a box sitting in my garage, I got a new car and ended up swapping column and box to avoid any possibilities.
Old Mar 13, 2011 | 09:32 AM
Jcase350's Avatar
Re: VATS Module
I have a #10 key...3.74 ohms.
Old Mar 13, 2011 | 09:55 AM
84redta's Avatar
Re: VATS Module
sorry, my key/box is a #12...6.04 ohms
Old Mar 13, 2011 | 10:11 AM
Jcase350's Avatar
Re: VATS Module
Much appreciated anyway!!
Old Mar 13, 2011 | 04:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: VATS Module
Will the starter not turn, or will it turn but not getting engine to start?
Old Mar 13, 2011 | 05:02 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: VATS Module
you could always get a bypass box and eliminate the VATS problem once and for all...
Old Mar 13, 2011 | 06:02 PM
Jcase350's Avatar
Re: VATS Module
The starter doesn't engage at all. I had to run a hot wire to the starter until I get it fixed.
Old Mar 13, 2011 | 06:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VATS Module
http://www.bakerelectronix.com/products_vats/
Old Mar 13, 2011 | 07:26 PM
Car: 1992 RS
Engine: Carbed 350
Re: VATS Module
If the car starts with your added starter wire, and runs, then it's not a VATS issue - VATS disables the starter AND the fuel injectors, so if it's running, fuel injectors are getting current - NOT a VATS issue.
You need to look at starter enable relay, nuetral safety switch, or ignition switch issues.
http://www.austinthirdgen.org/index.php?pid=38
Old Mar 13, 2011 | 08:21 PM
84redta's Avatar
Re: VATS Module
maybe bad starter relay? wow it would help if i read lol. my bad.
Old Mar 13, 2011 | 08:30 PM
Jcase350's Avatar
Re: VATS Module
Is there a way to test the starter relay? Also which relay is it?
Old Mar 13, 2011 | 08:33 PM
travis401's Avatar
Car: 91 Camaro RS
Re: VATS Module
its under the driver side kick panel...most likely buried under a square of black goo
Old May 22, 2011 | 10:30 AM
Jcase350's Avatar
Re: VATS Module
I think I have it narrowed down to the neutral safety switch. I have a B&M shifter automatic megashifter. Is there any harm in splicing the 2 wires together and bypassing the switch altogether?
Old May 22, 2011 | 11:33 AM
travis401's Avatar
Car: 91 Camaro RS
Re: VATS Module
Potentially yes. That switch keeps you from starting the car while in gear. With it bypassed, you could be able to start the car in reverse or drive, whih is never a good thing. It would be best to just fix it or replace it.
Old May 22, 2011 | 07:23 PM
Jcase350's Avatar
Re: VATS Module
Still no luck...it's not the starter relay, VATS, ignition switch, or the neutral safety switch. What else is there?
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
