connector where to plug it? (pic)
Old Mar 19, 2011 | 11:57 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
hello
i have another connector for you guys to figure out. so i was just looking into my engine again and i saw this connector and was wondering what it is for and should it be plug into something??
thank you
here are some pics.
Old Mar 20, 2011 | 12:06 AM
Countryguy's Avatar
Car: 91 Camaro RS
Engine: 383 Stroker Built
Transmission: Turbo 350
Re: connector where to plug it? (pic)
Looks like a vacuum line, where it goes I couldnt tell you. Hopefully someone will chime in!
Old Mar 20, 2011 | 02:38 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
From it's location looks like the vac feed inside car to operate vents.
Usually has a one way valve on it and possibly goes to the plugged line off the TB shown in 2nd pic
Normally has a connection to a vac reservoir somewhere as well
TPI one shown but same setup
Old Mar 21, 2011 | 02:39 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
ok thanks guys i will take a closer look at it .
but it looks like it's not that important for the engine right?
Old Mar 26, 2011 | 10:23 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
* UPDATE *
i now know what that is , yeah it is a vacuum line that goes from driver side sensor (map or whatever sensor is that ) how i figured it out. i had check engine light on (code 34) i saw that the vac line was connected at the sensor but the other end of the line was not connected to anything so i plugged it into that tube shown in the pic. and the check light went off.
Old Mar 27, 2011 | 12:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Your MAP sensor is located in your first pic, upper left corner, attached to the cowl lip. It is missing a vacuum line in your pic - maybe that's it in your last pic that's plugged off. The vacuum connector you are questioning looks like the one for the heater diverter valve.
Old Mar 27, 2011 | 06:29 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
im not sure about that some people say that there should be no vacuum line hooked up to that sensor on L69 HO engines but should be hooked up to the other sensor on driver side. that sensor looks the same as on the pass side but has gray connector instead of green connector. i will take pics tomorrow to show what im talking about.
here is a link i came across when i did research
https://www.thirdgen.org/forums/tech...-question.html
Old Mar 27, 2011 | 10:52 PM
heinousacts's Avatar
The vacuume line from the map goes to the back of the tb, in your second pic it has a plug in it. you need to connect that.
The one you have looks like the vent switch.
if it is, it plugs into the back of the intake.
When you switch from defrost to floor does it work?
Old Mar 28, 2011 | 11:02 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
Yes my vents inside the car work perfectly as they should no problem here.
Old Mar 28, 2011 | 11:08 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
ok guys here are some pics. i took today.
any input on this would be great
eightsixseven
Dec 16, 2024 01:50 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
BurlyChev
Aug 22, 2015 01:52 PM
djmarch
Aug 19, 2015 12:07 PM
mx127
Aug 10, 2015 08:13 AM
