Stupid question about the location of engine ID
Old Apr 12, 2011 | 03:27 PM
Puppetz's Avatar
Car: 1982 Pontiac Trans Am
Engine: 350 CARB
Transmission: Not as many gears as I want.
So I have a 3970010 block in my 82 trans am. I want to find out more information while the engine is still in the car. I know I can check the stroke to find out exactly what CID it is. I've heard of a plate in front of the passenger head with the engine ID stamped on it but I cant find anything. I ripped the alternator off and everything. All I see Is a "G" that was cast into it, not stamped, on the head itself. Am I not seeing the damn thing or what? Is there another way to find all the info on this block?
Old Apr 12, 2011 | 03:40 PM
74Novaguy's Avatar
Car: 88 Camaro IROC-Z
Engine: 5.7L 350 TPI
Axle/Gears: Stock
Re: Stupid question about the location of engine ID
In front of the passenger head on the block theres a machined area that has some letters and numbers stamped into it. it will tell you what it came out of and ci when you run it online.
Old Apr 12, 2011 | 03:55 PM
Puppetz's Avatar
Engine: 350 CARB
Yeah I've heard that a lot but I'm not finding anything. Any other ways to tell?
Old Apr 12, 2011 | 03:58 PM
74Novaguy's Avatar
Axle/Gears: Stock
http://ww2.justanswer.com/uploads/AS...inedetail1.jpg
http://ww2.justanswer.com/uploads/Da...gine_stamp.jpg
Old Apr 12, 2011 | 04:33 PM
Puppetz's Avatar
Engine: 350 CARB
Alright. Well I was looking for it at 2 in the morning and then there were shots fired in my neighborhood. I'll look tonight when I get home from work. Thanks.
Old Apr 12, 2011 | 05:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It'll only tell you what the engine was originally, which isn't necessarily anything like what it is now.
Old Apr 12, 2011 | 06:24 PM
Puppetz's Avatar
Engine: 350 CARB
Yeah, but it will give me a better idea of what I want to do with the thing. I wanna know specifics before I start modifications. The guy who owned the car before me was kind of dumb and "not so practical" with his setup. Regardless, I got the car with that motor and an extra 305 on a stand for 300 bucks total. fun summer ahead of me.
Old Apr 12, 2011 | 07:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
So far, all you know is that you have an 010 block. All that means is it's a 4" bore block. That casting was used on 302, 327 and 350 engines but there's a good chance it's only a 350 since millions of them were made during the time that casting was in use.
Without pulling a head off, you won't know if it was ever bored out or not. Since it's not in the original vehicle, anything could have been done internally.
Old Apr 13, 2011 | 10:48 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's all the specifics you're going to get without tearing down.
Old Apr 13, 2011 | 11:01 AM
74Novaguy's Avatar
Axle/Gears: Stock
Not true... If you can read the Block Suffix Codes that are stamped in front of the head. It will tell you CI and what HP and what it came out of.
heres a pretty good site. http://www.73-87.com/chevy_ids/sbcid2.htm
Old Apr 13, 2011 | 11:05 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Again... which makes not a lick of difference, because you have absolutely no way of knowing what's been done to it in the intervening 40 years since it was actually in that platform.
Old Apr 13, 2011 | 12:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
It may not have the original heads. It may have been bored out. It may not have the original camshaft. All the suffix code will tell you is what it originally came from and what the original rating was.
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
