Where do I begin to look
Old Apr 28, 2011 | 01:46 AM
fredbear's Avatar
Car: 1989 IROC-Z
Not really a serious issue, when I start the engine 350 tip it starts then goes real low....like its almost going to stall till I give it a short hit of gas then its fine....
On acceleration sometimes it sort of lags before power comes and even then its not to its potential. I have been having some issues with the fuel pump running. I was told to check the oil pressure relay next time it acts up.
When the pump was still (car off)on I heard like a low hissing noise coming from this gage up by the tpi A gage I have never seen before on these engine's....I unhooked the fuse thing (by the battery right?) and the pump and hiss was still present. It wasn't until I unhooked the battery that it went away.
I will post a pic of that gage latter
Old Apr 28, 2011 | 08:30 AM
fredbear's Avatar
Car: 1989 IROC-Z
Re: Where do I begin to look
the second photo of gauge is when engine was running....... I was also wondering why this gauge is here in the first place?
Attached Thumbnails Where do I begin to look-p1110475.jpg   Where do I begin to look-p1110476.jpg
Old Apr 28, 2011 | 08:37 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
fuel pressure gauge.
Old Apr 28, 2011 | 08:40 AM
StrahlZ28's Avatar
Car: 1991 Z/28
It's an aftermarket fuel pressure gauge that someone installed on the schreder valve. The hiss could be a sign that it's junk. I would let the fuel system depress and remove it, replace it with another schreder valve and see if your issue goes away... but if it's right your fuel pressure isn't bad.
Old Apr 28, 2011 | 09:23 AM
fredbear's Avatar
Car: 1989 IROC-Z
I don't know is it right should it be reading 40?
Old Apr 28, 2011 | 09:26 AM
StrahlZ28's Avatar
Car: 1991 Z/28
I think 350 TPI (stock) run around 45 PSI at priming and drop into the high thirties while running.
fredbear's Avatar
Car: 1989 IROC-Z
sorry nevermind I found out its normal. maybe Ill check the gauge next time it acts up
Old Apr 28, 2011 | 03:57 PM
fredbear's Avatar
Car: 1989 IROC-Z
Alright it just done it again and the gauge was reading 50 any ideas????? not running
Old Apr 28, 2011 | 07:14 PM
fredbear's Avatar
Car: 1989 IROC-Z
well I guess Ill just take it to the garage........I dont want them just to take out the fuel pump and say its fixed...what shouyld I tell them
Old May 4, 2011 | 11:03 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
have you checked the fuel filter? when was you last tune? are you sure that the FP is holding pressure?
ZZ3Astro
Aug 13, 2019 12:57 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
starliner
Feb 9, 2016 08:18 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Marc Brown
Sep 28, 2015 01:40 PM
