Stupid jacking up question
Old May 1, 2011 | 03:27 PM
native1031's Avatar
I need the wheels to hang freely, so instead of the a-arms where should i put jack stands.
Read a thread to jack it up from the cross member under the engine?
Old May 1, 2011 | 03:43 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Stupid jacking up question
i use the subframes as a jacking point and a place to put the stands
Old May 1, 2011 | 03:56 PM
native1031's Avatar
Thats where the sheet metal points down along both sides the car correct? Obviously you dont do it in the middle of the car but yea
Old May 1, 2011 | 04:16 PM
Put your floor jack under the center of the K-member, which is the big piece you see up under there in between the exhaust and the steering linkage. Put your stands just in front of the big holes in this pic, which is just behind and inboard of the tires.
Old May 1, 2011 | 05:02 PM
native1031's Avatar
are you talking about where I put the black circles?
Old May 1, 2011 | 06:27 PM
TNT_Z28's Avatar
thats where i put my stands
Old May 1, 2011 | 06:35 PM
Yup, that be the place...
Old May 1, 2011 | 06:43 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the same with the rear . remember the only stupid/dumb question is the one that is not asked . good luck .
Old May 1, 2011 | 07:59 PM
native1031's Avatar
Thanks a lot.
I screwed myself...
While trying to remove the pump(taking brackets with it) I stripped the last nut . Its behind the pump in like a little pocket.
What should I do? So friggin frustrated
customblackbird
Aug 15, 2021 10:16 PM
Cleotiz
Jan 6, 2018 08:56 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
