Heater core issues?
Old May 5, 2011 | 06:49 PM
McNabb1911's Avatar
Car: 1985 Z28
Engine: 355 4 Bolt main
Axle/Gears: Stock
Heater core issues?
I have an issue and i think i know the problem, but i want a few more opinions before i go to work. Im pretty sure, no i know the heater core is bad in my car. It drips on the passenger floorboard, but thats besides the point. After the car has warmed up, a vapor flows out of all the air vents and has a nice way of fogging my windows on cold rainy days. I think this is because the heater core is shot. Any other ideas before i tear into it?
Old May 5, 2011 | 07:29 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
Re: Heater core issues?
yep, if you knew it leaked then it wasn't a surprise to find the windshield fogging because that's one characteristic of a leaking heater core. Mine was doing this exact same thing in December, replaced it and the fogging went away. Its actually pretty easy to change it out, took me and my dad a little over 2 hours to take it out, just remember that there are 2(If I remember correctly) screws at the top of the heater core cover that you can get to from the top of your dash after removing the dash pad. You just need to make sure you don't rip the in and out hoses that connect to the heater core at the firewall when you take them off of the old one.
Old May 5, 2011 | 07:53 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's the heater core - replace it or bypass it.
Old May 5, 2011 | 08:56 PM
Adrian87Camaro's Avatar
Car: 1987 Chevrolet Camaro
Engine: 305 ci LG4
Transmission: TH-700R4
Axle/Gears: 2.73 non-Posi
I'm replacing my heater core right now but both NAPA and Autozone have given me the exact some heater core. It doesn't fit. It is really loose and when you try to put on the hoses it just slides back into the housing. I got my old heater core from Autozone 6 years ago, the guy there showed me on the computer that m old one is the same part # as the new one he gave me. Where did you get your heater core??? I might just take it to a radiator shop and see if I can get it patched up.
Old May 5, 2011 | 08:59 PM
Engine: 305 ci LG4
Actually just checked out O'Reilly's website and based off the picture it looks exactly like my old one. Gonna check it out....
Old May 5, 2011 | 09:07 PM
Engine: 305 ci LG4
Called O'Reilly's and what they have in-store is different than what they show online
Old May 5, 2011 | 10:36 PM
McNabb1911's Avatar
Car: 1985 Z28
Axle/Gears: Stock
Alright guys thanks im going to replace it soon then.
Old May 5, 2011 | 10:38 PM
Shadow Z's Avatar
Car: Lots of 'em
My heater core has some issues too. I hit it a few times with a hammer after I took it out.
Old May 5, 2011 | 10:40 PM
McNabb1911's Avatar
Car: 1985 Z28
Axle/Gears: Stock
That sounds like a good idea
Old May 5, 2011 | 10:43 PM
you might need someone to hold it in place from inside the car while you attach the hoses to it
Old May 5, 2011 | 11:03 PM
Engine: 305 ci LG4
I can have somebody hold it but once I close everything up it will still be loose in there and will not seal properly. The old one was nice and snug and fit perfect. I've looked at AC Delco, O'Reilly, NAPA, and Autozone and they're all selling the same heater core. Definitely frustrated with this one.
Old May 6, 2011 | 05:06 PM
McNabb1911's Avatar
Car: 1985 Z28
Axle/Gears: Stock
Have you tried hose clamps?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
TBRays98
Sep 6, 2015 05:05 PM
