Will a flywheel off a 91 305 work on a 383 stroker
Old May 20, 2011 | 04:48 PM
77camaro383's Avatar
I recently bought a 383 stroker from summit thats externally balanced. Ive been hearing that 305s are also externally balanced. So i was wondering if this is true or do I need to use a balance plate
Old May 20, 2011 | 10:31 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Will a flywheel off a 91 305 work on a 383 stroker
i used a 305 flywheel on my 355, no problems that i can tell... if that helps
Old May 20, 2011 | 10:45 PM
JtadaK's Avatar
Car: 83 Z28
Engine: Big Cam 327
Transmission: 5 speed
Axle/Gears: 10 bolt gm stock
I tried my 305s plate on my built 406 and it WILL not work! Anything above 350 is externally balenced and you need a plate that is. Anything under350 is interally balanced. Learn from my mistake, I had many problems dealing with this situation. Make sure its an exterally balenced plate!
Old May 20, 2011 | 10:50 PM
TNT_Z28's Avatar
Good to know. Your referring to flex plates, is it the same for flywheels?
Old May 20, 2011 | 10:51 PM
JtadaK's Avatar
Car: 83 Z28
Engine: Big Cam 327
Yes, I'm sorry flexplate. (Automatic)
Old May 21, 2011 | 12:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
305s are internally balanced.
Old May 21, 2011 | 11:41 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
do a search on internal and external balance. there is a lot of good info on here about it.
Old May 21, 2011 | 11:53 PM
Engine: 350 for now
Transmission: wc t5
https://www.thirdgen.org/forums/post...152-post3.html
this should help you.
Old May 22, 2011 | 07:51 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
400 engines only came with old style 2 pce RMS cranks which have a different crank bolt pattern to the 1 pce RMS cranks that most ('86+ ) 305's are
Any 2 pce seal (283 / 305 /327 / 350 ) flexplate will fit and bolt up to a 400 crank; whether the balance is correct is a completely different story
mhatfield 14
Oct 24, 2015 07:48 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
BlackphantomZ28
Aug 31, 2015 10:29 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
