92 305 tbi wont start, getting spark, spraying fuel
Old Jun 13, 2011 | 07:11 PM
Deluca119's Avatar
Heres the backstory, the car was getting harder and harder start last week, towards the end of the week i could not get it to maintain an idle it would just skip around, so this weekend i knew a tune up was in store, i changed the cap rotor pcv plugs wires ignition module and fuel filter, i cranked it and it still did not start. So took the wire for the first plug grounded it to the engine and i can see spark when i crank, next i took off the air cleaner and i can see the injectors spraying when i hit the gas and when i first turn the key. My father brought home a pressure gauge today, we had to jerry rig it because it didnt have the right fittings so i dont really trust the reading, however, sometimes i would get 6 psi, which is low and others nothing would happen, but i believe the gauge could aid to this. When i try to crank it almost sounds advanced, although i did not touch the distributor just changed the rotor cap and ignition module. Infact i have a video of me cranking it. Any thoughts are GREATLY appreciated:
Old Jun 13, 2011 | 08:19 PM
Vader's Avatar
Re: 92 305 tbi wont start, getting spark, spraying fuel
After fuel and ignition, you need compression and the correct timing.
Do you have an in-line spark tester to verify there is spark, just in case the plugs are soaked?
Old Jun 13, 2011 | 08:53 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
mine was doing that, turned out to be the little rubber line thats goes from the fuel pump to the metal hose going out of the tank, its about a 1" long and was cracked it was spraying fuel but not enough
Old Jun 13, 2011 | 08:59 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Try spraying starting fluid into the air intake and then crank over.If it starts (briefly) then its fuel delivery.
Old Jun 13, 2011 | 09:08 PM
Deluca119's Avatar
No however, im willing to purchase one because it will come in handy. Ill look into that and borrow a compression test gauge. I will definately look into the hose tomorrow aswell
Warren-i've done that before the engine backfired and burnt my injector harnesses to a crisp
Old Jun 14, 2011 | 04:16 PM
Deluca119's Avatar
Ok, i just lined up the timing mark on the pulley with the mark on the gears, stuck a screw driver in the 1 spark plug spot and I hit something, so i took off the dizzy cap and found the rotor pointing in a different spot. I changed my spark plugs based on that, and made sure it was spinning and the timing chain hadnt broke, i lined everything up put the wires in the new spots triple checked it, cranked it and still no dice, injectors are spraying and i believe i still have spark, i dont want to keep cranking because ill just flood the engine.
Old Jun 15, 2011 | 02:30 PM
Camaro91327's Avatar
Car: 1991 camaro RS
Engine: 408 Stroker
Transmission: 4L80e
heard backfire in the vid i think a little bit. timing seems to be your issue. make sure both valves are closed when cylinder 1 is at the peak(Compression Stroke) of its revolution. than adjust rotor. right now your car seems to firing on intake stroke. Intake, compression, power, and exhaust.
Last edited by Camaro91327; Jun 15, 2011 at 02:48 PM. Reason: watched more vids :)
Old Oct 20, 2012 | 08:43 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
what was the prob so i can fix my baby it keeps fooding
pimp2303
Jul 27, 2017 02:03 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
