this is the cause of my misfire i believe
Old Jun 19, 2011 | 12:41 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
on my iroc tpi, after new plugs, wires, msd cap and rotor, and new coil.. after i used seafoam in the gas.. after 25 miles this is the result.. only the left side was fisfiring like crazy.. heres the pics of the left plugs. sorry for the huge pic.
Old Jun 19, 2011 | 01:56 AM
jeff_blake's Avatar
Re: this is the cause of my misfire i believe
*misfiring.
Old Jun 19, 2011 | 03:47 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
It looks like your plugs are seriously carbon fouled. That normally points to improper tuning. You should take a look at the air filter, ignition components, and engine control system.
Well atleast thats what Chilton suggests!
But that more than likely is the problem with the misfiring.
Old Jun 19, 2011 | 03:56 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
What do the right side plugs look like? Could you really have all plugs on just one side misfiring? That would be odd. Excessive fuel could also cause that. If the right side plugs are clean, check the injector fuses.
Old Jun 19, 2011 | 04:45 AM
jeff_blake's Avatar
yeah, I know for sure it's running rich, just redid all the ignition for the most part. just trying to get it tuned in. and yeah doc, it's only doing it on one or 2 cylinders on the back driver side plugs. as for the passenger side. they do have little carbon build up but not nearly as bad as the driver side. kinda weird.
Old Jun 19, 2011 | 04:46 AM
jeff_blake's Avatar
and my injector fuses are good, first place I checked, and double checked.
Old Jun 19, 2011 | 04:49 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Verify no runner gasket leaks, then suspect your injectors.
Old Jun 19, 2011 | 04:52 AM
jeff_blake's Avatar
no runner leaks.. has pretty much all new sensors other then Maf. dont think that works, but then again it's not throwing a code at me.
Old Jun 19, 2011 | 05:12 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The fact that the problem is affecting only a few cylinders would indicate that it is not sensor related but rather specific to those cylinders. Air leaks in all the other cylinders would trick the system into adding fuel, making those few cylinders run rich. Otherwise, it can really only be the injectors. A weak spark can leave the plugs dark but we already know that's not the problem.
Old Jun 19, 2011 | 01:05 PM
jeff_blake's Avatar
alright cool thanks doc. much appreciated on my days off I'll do some more investigating and we shall go from there.
db057
Jan 10, 2020 08:55 PM
NZKnight
Oct 15, 2015 02:47 PM
camarohelp
Sep 22, 2015 03:19 PM
Jk_Under
Sep 8, 2015 08:13 AM
Thaney9
Aug 29, 2015 03:16 PM
