shiny side
Old Jul 20, 2011 | 07:46 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
shiny side
As I had recently rebuilt my 350 and used quality parts I have a dilemma.My car started smoking so I pulled the heads and both(882) were severely cracked.I just ordered a new set from KMJ(aluminum)as I reassemble, can I still reuse roller tips with nuts and such and same pushrods? I just had standard pushrods ,do I need hardened or longer? Next,I have not moved cylinders since pulling HEI (marked)so can I install new heads and rest of components w/o retiming? Some say use intake valley gaskets some say use sealant(thoughts?)Last thing, does the shiny dimple side go in or out on the exhaust manifold?
Old Jul 20, 2011 | 10:30 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: shiny side
Yea, that's a common problem with 882 heads. Paper thin and prone to cracking.
- Re-use pushrods - yes, as long as your camshaft, valve length, rockers are the same, no problem.
- Roller tip rockers - yes.
- HEI - Should be fine, but you'll want to double check your timing after you get it running again just to be sure.
- Intake "china wall" gaskets - your choice. It's a matter of personal opinion. I used the black rubber ones, but my car leaks like a seive (not sure from where...), so take that as you wish...
- Shiny dimple side? You're talking about on exhaust gaskets? I must have used different style gaskets than you, so i'm not sure. I doubt it matters -but perhaps someone else can chime in.
Old Jul 20, 2011 | 11:13 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Re: shiny side
yes it was the exhaust gaskets that came in my AZ kit.thanks for your input.
Old Jul 20, 2011 | 04:29 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Re: shiny side
If your new heads have pushrod guideplates than u need hardened pushrods...
Old Jul 21, 2011 | 10:06 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Re: shiny side
Heads arrive today and I ordered new hardened pushrods and now I need 1255 intake gaskets because the ones in my set are for heads with heat ports
Old Jul 23, 2011 | 04:41 PM
383firebirdokc's Avatar
Car: 84 trans am 383 stroker
Engine: 5.7 383 stroker
Transmission: PRO BUILT 700r4 tranny
Axle/Gears: 3.73 rear disc posi
Re: shiny side
if you have installed the heads how are they holding up I afraid to buy cylinder heads that are not proven but I never hear anything bad about KMJ cylinder heads.
Old Jul 24, 2011 | 07:19 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Re: shiny side
I am still working on reassembly(kinda hot here so I am going at it pretty slow)Hope to have it running by next week and to be sure, I will report on how this plays out.
Old Jul 24, 2011 | 05:22 PM
Re: shiny side
yeah it was either I buy a pair of these or I was going to save up for trickflow's My wife would prefer the budget type heads LOL. Yeah get back to me hope it works well for you.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
sbrandon
Sep 9, 2015 07:31 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
