HELP!!! 82 sport coupe wont start
Old Jul 27, 2011 | 02:44 PM
jakjak1's Avatar
Car: 1982 camaro sport coupe
Engine: 2.8l v6
Transmission: auto 3 speed
had the car for a month started fine every time then just stopped turning over. i checked the oil and replaced the all the fuses. makes absolutely no sound when i start it but lights come on and the batter isnt dead. i was told it might be the ignition switch so i replaced that but it still wont start...
whats wrong with it?
Old Jul 27, 2011 | 09:50 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: HELP!!! 82 sport coupe wont start
check your neutral safety switch
Old Jul 27, 2011 | 09:52 PM
jakjak1's Avatar
Engine: 2.8l v6
how do i do that?
Old Jul 27, 2011 | 10:09 PM
jtsk's Avatar
Your NSS is attached to your shifter. It is kind of C shaped. There should be a tang sticking out from it that engages your shifter and it will have wires attached to it. First, try pulling the shifter to neutral and starting it. If that doesn't work, you can put it back in park and take your console shift plate off. Then remove the NSS and unplug the connector and jump across it with a wire. IF it starts or at least tries to start then you need a new NSS, if it doesn't do anything, then the problem is elsewhere and you can hook everything back up. I don't remember which connector pins to jump offhand, so you'll have to experiment a bit. Be sure you have your parking break set and the shifter in park before you try starting it. There may be another way to test, but this is the way I have always done it.
Old Jul 27, 2011 | 10:14 PM
jtsk's Avatar
Hey, just by chance, is your steering column tilted up all the way? We had an 86 z28 once that when the column was tilted up, it wouldn't do anything. Had a bad connection in the steering column wiring somewhere.
Old Jul 27, 2011 | 10:36 PM
jakjak1's Avatar
Engine: 2.8l v6
ok ill try the nss tomorrow and i dont have a tilt steering wheel
Old Jul 28, 2011 | 07:45 PM
jakjak1's Avatar
Engine: 2.8l v6
it didnt work
Old Jul 29, 2011 | 08:52 AM
jtsk's Avatar
It didn't work as in you jumped across the wires on the harness or pulling it to neutral to try and start it?
Old Jul 29, 2011 | 12:30 PM
jakjak1's Avatar
Engine: 2.8l v6
neither worked
Old Jul 29, 2011 | 12:41 PM
jtsk's Avatar
ok, sounds like either a burnt wire or a blown fuseable link. You can get under the car and trace the small wires from the starter solenoid and see if they are burnt or melted. As for the fuseable links, you would need to get a service manual and check out the schematics for locations. You might also find some help from some other threads on this site by doing a search.
Old Jul 29, 2011 | 12:50 PM
jakjak1's Avatar
Engine: 2.8l v6
k thnks ill look into it
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
