strange engine feel
Old Jul 29, 2011 | 01:23 AM
built's Avatar
Car: 82 TA
strange engine feel
I have a 82 TA with 305 with quadrajet carb,
I'm having a weird problem, the engine has always run a little hot but runs hotter now since i lost the bottom shroud portion around 210 degrees .
The issue is when I'm driving on the highway for about a hour steady it will kinda hesitate and I have to give it more gas and the exact same time the check engine light will come on but once I park for awhile the light goes off and everything runs right.
Any idea what is wrong?
Old Jul 29, 2011 | 05:42 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Re: strange engine feel
GM Check Engine light Codes without a Scan Tool
read this, pull your codes, and get back to us.
Old Jul 30, 2011 | 12:21 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
the shroud is there to pull the air through the radiator....find a lower piece and put it on problem solved....
Old Jul 31, 2011 | 01:17 AM
built's Avatar
Car: 82 TA
I haven't had time to pull the code but i will and get back with you.
I have tried looking everywhere for a new shroud, can't find any.
I really need a upper too mine is rough.
Old Jul 31, 2011 | 03:31 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Originally Posted by built
the engine has always run a little hot but runs hotter now since i lost the bottom shroud portion around 210 degrees...
Assume you are referring to the shroud around the fan, not the air dam. The fan needs to be fully shrouded to make sure all the air flow is pulled thru the rad, rather than in from the sides behind the rad, or allowing hot air to recirculate back thru the front of the rad.
Getting too hot will result in all kinds of narky behaviour, especially with a carb.
Old Jul 31, 2011 | 04:03 PM
built's Avatar
Car: 82 TA
yes the shroud around the fan.
you would think since 82 to 92 there would be one in a junk yard for firebirds or camaros but no luck around here.
Old Aug 1, 2011 | 05:34 PM
built's Avatar
Car: 82 TA
today noticed a buzzing sound coming from behind the dash around the choke light with the engine off and key not even in, later it wouldn't start,dead battery. I'm thinking alternator time.
Old Aug 3, 2011 | 06:42 PM
built's Avatar
Car: 82 TA
today I changed the alternator and everything is fine now, no buzzing and engine runs good, didn't even try the code trick. I'll see how it goes awhile and maybe check it anyway.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
