i need HELP! car wont crank
Old Aug 9, 2011 | 11:35 PM
ant916's Avatar
I have a 86 iroc z 305 tpi that won't start Wen I turn the key I can gear the fuel pump engage but when I turn the key nothing happens the starter won't crank click or anything n I took the starter out and had it tested but it passed and the guy from autozone told me to have the cylinoid checked I was wondering Wat else might be the problem? So please help me I need to fix it fast
Old Aug 9, 2011 | 11:44 PM
leedavidalan's Avatar
Re: i need HELP! car wont crank
this happened to me once and then i realized i had the kill switch on.
Old Aug 10, 2011 | 12:06 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
bad connection. does you key have a little black pellet chip in it? your vehicle anti theft system might have malfunctioned. if you go to the wiring harness loom by the brake master cylinder you can pull out a bigger purple and red wires. jump the wires together and see if it cranks the car. the key will need to be on and in park w/parking brake set for safety reasons. other then that your neutral safety switch could be acting up. does the car start in neutral? or in another gear? again be sure to hold your foot on the brake. that's where i'd go.
and also i have seen plenty of starters pass the bench test and not work on the car
Old Aug 10, 2011 | 12:08 AM
ant916's Avatar
I don't think mine has a kill switch tho Haha
Old Aug 10, 2011 | 12:15 AM
ant916's Avatar
Originally Posted by UnderCover89TBI
bad connection.b does you key have a little black pellet chip in it? your vehicle anti theft system might have malfunctioned. if you go to the wiring harness loom by the brake master cylinder you can pull out a bigger purple and red wires. jump the wires together and see if it cranks the car. the key will need to be on and in park w/parking brake set for safety reasons. other then that your neutral safety switch could be acting up. does the car start in neutral? or in another gear? again be sure to hold your foot on the brake. that's where i'd go.
I actualy have a 86 but I had to get a new steering column so I found one but its a 90-92 air bag steering wheel and the key does have a chip in it
Old Aug 10, 2011 | 12:25 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
but did the car get the whole vats system? doubtful. probably not your problem. did you test your battery and ensure the connections on them were good, clean, tight?
Old Aug 10, 2011 | 12:30 AM
ant916's Avatar
No my car never had vats its just the steering column I got is from vats camaro but I'm not sure Wat else to try
Old Aug 10, 2011 | 09:47 AM
jamienoel's Avatar
Car: Mystifying 1989 TBI Camaro.
Engine: 1992 350 Truck Engine. TBI
Transmission: 700R4 when it wants to be.
Did you make sure the connector on the column that has the rod running to it was correct? You could try swapping it (it's a switch) with your old one. I think it only has two screws/bolts holding it on, but it's been awhile since I changed my column, so I could be wrong.
Couldn't hurt to check it.
Old Aug 10, 2011 | 01:51 PM
ant916's Avatar
yea the metal bar coming from the ignition cylinder connecting to the switch i swapped to the older one next to the high beam switch
Reborn756
Sep 4, 2015 03:42 AM
TheExaminer
Aug 26, 2015 04:59 PM
Thirim
Aug 13, 2015 03:09 PM
mizz0313
Aug 12, 2015 06:45 AM
gwade12
Aug 8, 2015 08:17 AM
