Intake man bolt locations.
Old Aug 20, 2011 | 12:57 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Quick q before I put it on. I think I numbered #7 and #8 wrong. The 4 long bolts go on each corner right?
Old Aug 20, 2011 | 02:51 PM
Damon's Avatar
Re: Intake man bolt locations.
4 longs are the 2 center bolts on each side in 87-up applications, as far as I can remember. Could be wrong about that. Somebody else will chime in here soon to confirm.
Old Aug 20, 2011 | 05:57 PM
Mr Froman's Avatar
I mean I numbered them as I took them off and all but one long is on each corner. And that's when I realized step 8 was actually step 7.
Old Aug 20, 2011 | 06:40 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Just installed an intake on an 88 TPI last week, and all 12 bolts were the same length.
Old Aug 20, 2011 | 07:46 PM
Mr Froman's Avatar
Not mine. Have four longer ones.
Old Aug 20, 2011 | 08:04 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
'85 Carbed Z28,all the same length here too.
Old Aug 21, 2011 | 08:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Can't answer the question directly, but wanted to add that you need to be careful. Using a long bolt in the wrong location can bend/bind up a push rod. Which leads to further damage.
RBob.
Old Aug 21, 2011 | 10:41 AM
Mr Froman's Avatar
Yup. The longer ones I put in the corners. I saw that the shorter ones stop before getting too close to the pushrods.
Old Aug 21, 2011 | 12:24 PM
Mr Froman's Avatar
SO mad.
Chilton said to tighten heads in 3 passes, ending with 65 ft. pounds and showed the bolt pattern.
Did so, engine is almost ready to run.
Was looking at a chart and it gives specific torque specs for each pass.
Terrell351
Jun 13, 2021 01:13 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
